Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheem natural gas water heater installed about 5 years ago has begun to fail every 4 days or so it needs to be re-ignited manually. Works fine again for several days but inevitably will cease again heating the water and need restart procedure. The flame when observing seems to turn yellow periodically and I hear what sounds like moisture dropping on the burner area. I have cleaned and vacuumed out the igniter space underneath several times, which may extend the timeframe for the next occurence, but not a long term fix. Help?
  • Rheem Master
  • 2,320 Answers
Well you might have a pinhole leak than periodically puts out pilot light. Or you might have a bad thermocouple. Thermocouple is inexpensive and easy replacement.
Posted on May 12, 2017
gary1121
  • 332 Answers
SOURCE: have a rheem central air conditioner heater. I
gas valve could be clogged it has a screen in the side of the inlet, check this first if not it could be the gas valve itself,, make sure the gas valve is turned on also, sometimes people turn them off and for get the handle should be in line with the pipe not across the pipe
Posted on Jun 06, 2009
gary1121
  • 332 Answers
SOURCE: the water heater will cycle 5-6-7 times with no
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
snap101
  • 117 Answers
SOURCE: Tankless Paloma NG hot water heater shuts down
have you checked the error codes on the heater?
you can do this by powering off the controler and pressing the up and down keys for a few seconds. this should take you into the diagnostics mode scroll using the up and down keys till you find the one that has the letter E on it and that will give you the last 8 error codes write them down and get back to me
Posted on Jul 29, 2009
  • 244 Answers
SOURCE: I am having the same problem as posted by jek01 on
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike
jzklipper@aol.com
Posted on Nov 11, 2009
heatman101
  • 43501 Answers
SOURCE: I have a 2 year
The flame sensor is bad....and it is not sensing that the flame has lit....
Some models have a separate flame sensor and some use the ignitor to sense the flame...
If it has a separate sensor then clean it with a soft cloth... if it is the ignitor then the ignitor is bad...
heatman101
Posted on Nov 25, 2010
My Jacuzzi J-N180F tankless water heater will not even light.
Access your product manual.
I cannot find a product manual.
Some major company, like Rheem, makes this computer that heats water.
Call service technician to repair the unit.
Copy following link for overview of type of problems found with tankless computers.
For example tankless computers require continual maintenance on yearly and monthly basis to prolong expected life of product.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If tankless computer is older than 5 years, then assume it is like your 5-year old laptop computer.
Save problems, and repair the unit yourself, same day, by installing tank-type water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 27, 2013 | Jacuzzi 7.5 GPM 180000 BTU Internal Gas...
Rheem tankless water heater error code 11
Error 11 is ignition failure, or insufficient gas, or defective sensor, dirty combustion parts.
Do the yearly required maintenance such as cleaning the combustion parts, and error code will probably be solved.
Problem is Rheem does not post service manuals for people to learn how to service their equipment without calling service tech.
Copy following link for Rheem troubleshoot resources
The cost of yearly maintenance will easily eat away the expected yearly savings of $100 for typical family of 4.
Aug 20, 2012 | Rheem RTG-66DVN Direct Vent Natural Gas
I have a Rheem rtg-74pvn-2 tankless water heater installed in 03/09. Intermittently the hot water stops when only the hot water tap is on. No error codes appear. Bill W.
Before calling service technician, open following links for resources including Rheem chat and possible manual:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Crossover.html
Typical tankless manual says to have yearly service which includes checking household plumbing, gas supply, vent and condensation, check sensors for loose wires, clean and inspect burner parts and ignition factors etc.
Aug 04, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I turn it on and it looks like everything is fine we use the hot water and it turns off and starts flashing C-7 & 76 before when it would shut down we would pull the pour cord and wait a minute and...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troublshoot-Rheem-Tankless-water-heater.html
Read manual thoroughly for troubleshooting and yearly maintenance requirements.
The manual has basic error codes and possible self-repair tips, but the same problem on one person's unit can be a different problem and different solution on another unit.
Repair most tankless problems yourself, same day, any brand for about $330
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 09, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem G75-125 natural gas. Water heater ignites and burns as it should for 5-10 seconds and then shuts off. The damper is open. All of the lights on the front cover light in proper sequence. I get 24 volts...
Suggested order of things.
1) Read manual troubleshoot and maintenance sections
Find same-similar manual at Rheem
http://www.rheem.com/products/commercial/water_heating/commercial_gas/
http://www.rheem.com/product.aspx?id=0697944D-D79A-40C1-BDEB-875E48200DD1
http://globalimageserver.com/fetchDocument.aspx?id=c0b73553-5f03-4a5e-8789-4732ffecdccf
Maintenance and troubleshoot sections might help solve problem.
Download manual to your computer as a resource.
2) Post question on pro water heater forum, and include details from manual, and link to manual, so pros don't have to search Rheem commercial water heater page to find manual.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Contact Rheem who will ask you for name of installer and servicing technician.
4) Call service technician.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 10, 2011 | Rheem Tank Water Heater G75-125, 75 Gallon
Unit wont run and thers no error code
1) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
http://www.rheem.com/hrc.aspx
2) Call local service technician, and put that person in your rolodex-wallet for future help.
When technician arrives, ask that person for tips and tricks keeping unit working with regular maintenance.
They will gladly offer yearly service.
3) Read manual several times get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
4) Read manual several times and notice word troubleshoot appears many times.
Since tankless are complicated machines, many internal and external factors can affect operation, especially as unit ages.
5) Look at label on unit to identify exact product number. Identify same/similar product at Rheem, and become familiar with Rheem website
6) Read other question/answers at fixya about Rheem tankless to become familiar with the tankless era
http://www.fixya.com/tags/rtg_74pvn
7) Install DIY tank-type gas water heater and avoid the whole headache
8) Add a comment for more free help.
Mar 16, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
BOUGHT THE UNIT IN JULY 2009 WORKED FINE UP UNTIL THREE DAYS AGO WHEN I RUN THE HOT WATER IT RUNS FOR A FEW MINUTES THEN SHUTS OFF.
Ask technician for tips and tricks for keeping unit working and needed maintenance.
They will gladly offer a yearly service.
3) Read manual several times to get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
Mar 14, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
I have a Rheem (Paloma) GT199XN tankless water heater. It has worked fantastic since I installed about 5 years ago. Just recently, I have have intermitten issues of the burner not firing up when we turn on...
Here's the order of things I would do.
1) Contact Rheem for name of qualified service technician.
2) Call technician who can fix your specific unit, and can educate you about maintenance, and tricks and tips. These guys learn something new each day and are good to have in your rolodex/wallet as tankless unit ages.
3) Download manual, or read manual cover to cover and review maintenance protocol to make sure you're on a schedule for de-liming and other things required for tankless to work.
4) Ask Rheem how you can become familiar with their website pages that show updates and other information that affect your specific unit.
5) Install ordinary tank-type back up that can be put online quickly in case tankless needs parts or frequent maintenance as it ages.
Feb 27, 2011 | Rheem GT-199XN Outdoor Natural Gas Heavy...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
59 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
