Question about Whirlpool ED5VHGXM Side by Side Refrigerator
I have a whirlpool side by side model # ED5VHGXMB10. It leaks water into the bottom of the freezer. I have re adjusted the water tube that dumps water into the ice maker thinking it was shooting over the catch basin. It seems to still be leaking and pooling in the bottom of the freezer. I assume it is leaking behind a panel in the back of the freezer. Thank you in advance for any help you can advise. duffy
    Guru:
  • 1,524 Answers
Below that panel in the freezer (evaporator cover) is the drain trough. Most likely it is clogged.
Using a baster, with hot water and bleach mixed deluge till it flows down to the drain pan underneath.
Posted on Dec 31, 2010
My whirlpool side by side Why is my whirlpool side by side refrigerator model ED2PHEEMQ00 leaking water out the door or the freezer side.
90 percent sure drain is clogged. when unit defrosts , water from said melting ice is drained away via drain hole and tube to underneaththe fridge. locate drain hole in bottom rear of freezer and pour hot water with turkey baster into hole until it runs out freely
Aug 31, 2014 | Refrigerators
Water leaking in from rear of freezer and freezing on bottom. Removed the back panel behind the fridge at the bottom, but didnt really see anything (not that i would know what to look for) out of the...
Take all food out of the freezer and remove shelves. There will be a cover on the back of the freezer compartment covering a fan and an aluminum evaporator coil. There should be a little ledge or lip under those components, there is a hole on that ledge where water will drain down through a tube to a little pan under your refrigerator. The tubing is clogged and there is probably ice blocking the hole, you will need to remove the ice with a hairdryer or hot water and dump very hot water down the hole until the clog breaks free,
Mar 16, 2014 | Whirlpool Refrigerators
Amana side by side refrigerator dumps a large puddle of water in front every month or so. Nothing in the owner's manual to help trouble shoot this problem. Model is SS25TE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,
there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Amana Refrigerators
LEAKS WATER ON FLOOR ON LEFT BOTTOM SIDE
Hi and welcome to FixYa, I am Kelly
Your model number is missing the last 3 digits. I will be using this model number as a reference: GB9SHKXLB00
Things to check:
1. Open the fiberboard rear cover and make sure the compartment drain tube is not blocked on the end of the tube. The tube is item 37 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170 Remove any debris from the tube end.
2. Clean out the drain catch pan completely. Item 8 this link: (just forward of the compressor) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170&diagram_id=28163869#d28163869 These can get really nasty. Do the best you can to visibly inspect the drain pan for cracks.
3. Check the freezer compartment drain funnel for obstructions. Item 47 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170&diagram_id=28194805#d28194805 Remove any obstructions.
4. There does not appear to be a drain tube from the evaporator drain funnel area Item 20 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170&diagram_id=28163869#d28163869
This design appears to dump water from the bottom of the evaporator into the bottom of the freezer compartment through the compartment drain (item 47 step 3 above) for draining.
To ensure that the freezer compartment tube / drain is clear direct output air from your vacuum into the drain tube (item 37 first link) tube under the unit and have a 2nd person listen or feel for air flow up out of the freezer compartment drain. This will also float out any debris from the drain tub that may not been visible.
This should resolve your water leak. Feel free to ask any future questions.
Thanks for choosing FixYa,
Kelly
Aug 03, 2011 | Whirlpool GB9SHKXL Bottom Freezer...
Leaking from a tube like object under the front of frig. It looks like a small pinhole in the bottom of tube. Can I take part off and replace
Here is a link to Whirlpools User and Part Manuals=> sea_breeze_21.jpg From the drop down choice choose Consumer and paste or write ED5VHGXMB10 and then click search.
And below is a link to Point and Click=> sea_breeze_6.gif I believe your water supply line has a pinhole in it and you should shut off the water at its source to pevent any electrical shorting. Here is a front view of your refrigerator=> ED5VHGXM10
I believe it is either the tube filter inlet or the tube filter outlet=> 8201597 or 2255153 You may find locally, If you need me please let me know, Thanks, Sea Breeze
Dec 11, 2010 | Whirlpool ED5VHGXM Side by Side...
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leak where hose meets refrigerator connector
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Mar 01, 2008 | Refrigerators
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
191 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
