Question about Duracraft Humidifiers
Duracraft DD-TEC10E Luftentfeuchter, am 30.12.2010 von Amazon geliefert. Im display erscheint E2, anstatt der rel. Luftfeuchtigkeit. Der linke Einschaltknopf (Nr. 2) schaltet nicht aus und die grüne Kontrolleuchte blinkt ständig. Was ist los? Erbitte Nachricht, dringend! Danke, Ingrid Bohle
What does a E2 mode mean how do I reset?
The '2' in E2 seems to refer to list of conditions under 'Troubleshooting' in the user manual for this product. The version of the manual that I have found claims that in this condition the problem is: "The amount of heated air exiting the front of the portable heater is reduced."
The solution is to: "Check the electrostatic filter to make sure it is free of dust and dirt. Also check the front grill and rear air intake to make sure it is not being blocked by any kind of debris."by BillBell
below is a few links and the last one is sun heat where you can contact them. press the helpful button,
http://www.qcsupply.com/media/pdf/20451_IOM.pdf
Sunheat SH1500 Space Heater Parts
Welcome to SUNHEAT INTERNATIONAL Family Owned and Operated Since 1954
Feb 02, 2016 | Sunheat SH-1500 Electronic Infrared Zone...
Borrowed duracraft 2831 6 m i d from my landlord. when i plugged it in it was working fine but had a very strong odour of wet plaster so i unplugged it and gave it a good clean. when i plugged it again the...
it was borrowed and not hired
it is at lenders liability and you are under no obligation to pay for it
It was faulty from the minute you plugged it in so he may be try to get a new one from you
if push comes to shove , ask for the original receipt for the item and if it is more than a few months old , then he has no legal claim for a new one
May 26, 2017 | Duracraft Humidifiers
Manual for a Honeywell K4392V2 M6983 RevB to solve ''BAT'' display
Check to see if you have a wireless remote that requires a battery, mine when bad and it was the wireless remote to turn on and off from outside.
Jan 23, 2010 | Honeywell Humidifiers
Humidifier fan blades stopped turning
Sounds like the brush is completely gone. You might be able to replace just the brush.
Good luck.
Mai
Apr 11, 2017 | Duracraft DCM200 2 Gallon Humidifier
Motor runs but water is not going down , no mist coming out, just air
i had the same problem but i think the water tension is too high and the wick does not **** it up..just like wearing a new t-shirt and you notice that water beads up on the cloth.After wearing it and washing it,the soap in the detergent will have removed/dissolved the water tension and allowing it to clean the shirt.This removal will allow the shirt to absorb moisture easier.Same as the wick for the humidifier.Try to leave the wick in the device for an hour or so.You may add a tiny pinch of salt but not too much.Or better ,leave the wick in the bathroom when you shower as the air borne water particles will settle into the wick and trigger off the absorption effect.I hope it works for you.
Dec 12, 2009 | Duracraft DCM200 2 Gallon Humidifier
No vapor
you need to take a soft toothbrush and some cleaning solution to clean the coils. if the coils are too build up of scale it can reduce the mist or not produce any at all. if that doesn't work there is something internal that is going on and i would check with the manufacturer if your under warranty to get a new one.
Apr 07, 2009 | Duracraft DWM-250 2.5 Gallon Humidifier
How do i clean the mold off my humidifier?
Fill it to with in an inch of full, add two tablespoons of clorox and fill it the rest of the way. Run it for a few minutes and then just let it sit over night. The next day empty it out and refill it with fresh water and one teaspoon of clorox. You will be good to go.
Apr 02, 2009 | Duracraft DWM-250 2.5 Gallon Humidifier
Can't get at the fan to clean
You cannot do it as it need a specialist's skill.What i do is to insert a bubble tea's drinking straw and insert it into a vacuum cleaner's attachment that is formed like a **** and attach the other end into the grills of the device and gently vacuum the dust away.Good luck.
Apr 14, 2008 | Duracraft DCM200 2 Gallon Humidifier
Humidifiers Logo
78 people viewed this question
Top Duracraft Humidifiers Experts
Mack Baxter
Dennis
Are you a Duracraft Humidifier Expert? Answer questions, earn points and help others
