Question about E-Machines eMachines Desktop PC
Is there any way to recover without recovery disk?
  • Narseman Dec 31, 2010
    That depends on what is wrong. There are many issues that can be fixed without a recovery disk.
    BSOD ? Look herehttp://www.pcstats.com/articleview.cfm?a... (For beginners)
    You need to be more specific about the problem
    Brigadier General:
  • 8,909 Answers
Only if you have a recovery partition on your hard drive. If you have try F8 at start up to get you into the startup menu for recovery.
Hope this helps.
Posted on Dec 31, 2010
How do i reset my toshiba notebook L305-S5918 without the disk
Check if it has a hidden partition to do factory reset of Windows 8.
Rigt click My PC
Clic Administration
Click Disk Administration
Hidden Recovery partition should appear without letter
Follow procedure to Factory reset from Recvery Partition
How do access Windows 8 Recovery partition and how to recover it to...
May 27, 2015 | Toshiba Computers & Internet
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
Advent 7211 recovery disk needed
Well,bro! your question is too simple, why do you need yo recover disk? Did you delete or formate some important files in the disk? And the most important is that have you save new data to the disk, which will have an effect on data recovery. OK, if you need to recover disk ,you can ask help for some data recovery program, such as Recuva, which is without paying,but it just can recover about 60% data, maybe you can choose other one, know more here: http://www.card-data-recovery.com/
Mar 23, 2013 | Advent Netbook
How to recover data from my toshiba 320 hard disk?
Data lost due to unintentional formatting of the drive or when someone knowingly delete some data later on realizing that the data was important, In situations like this one should use a data recovery tool. To know more about data recovery process visit http://www.recoverlostfile.net
Dec 23, 2012 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
How can i recover data on drive without reformating.
People often feel panic when I see this. If I format the drive, will I lose all my data? If not, how could I get access to my files?
My take is that you may try some data recovery software first, download this one called asoftech data recovery
Windows Data Recovery Software
If does not work, you may have to format (use quick format) the drive and then use recovery software to recover your files.Here's some information about format recovery, think you need to take a look, very useful
how to recover formatted files
Jul 27, 2012 | Hitachi Computers & Internet
Disk Doctors Photo Recovery (Mac) 1.0
Card Data Recovery for Mac is the powerful Mac photo recovery application that can recover deleted pictures from hard drive, camera, memory cards, fire wire drives, USB drives, etc. as well as all Macintosh based storage devices like iPhone, iPad, iPod, iMac, MacBook, etc. It supports Mac OS X 10.3 and above. Moreover, It is also compatible with latest Mac OS X 10.7 Lion.
May 13, 2012 | Disk Doctor Labs Disk Doctors File...
How do i do a recovery without a the disk
depends on what are you trying to recover?
if u want to recover the data then u can connect the hdd to any other external device and do the recovery.
if u want to recover the os then u can boot and recover from the system partation if u have one.
Jan 10, 2010 | E-Machines T2792 PC Desktop
Hard Drive recovery
Have you tried some data recovery software? You can use the Google search tool in this regard. .My Mac Book Pro hard drive has crashed and I'm in the process of replacing it. However, I had a lot of important data on that hard drive that he needs recovered. Then I found this data recovery software that recovers data from corrupt/bad hard drives. And fully supported for NTFS/FAT32 mac files. Mac Hard Drive File Recovery Recover Files from Formatted Mac Hard Drive
Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
E-Machines eMachines Desktop PC Logo
32 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
