Question about Garden
The other day it is running fine then all of a sudden it dies and won't start. air cleaner is clean. The a couple of days later, I start it and runs fine. I'm blowing off the patio and it dies again after about 8-10 min.
  • 6 Answers
Ignition coil fixed my Stihl backpack last fall
Posted on Feb 07, 2015
  • 11,896 Answers
If the air filter is clean, then you have either no spark or no gas. Gummed up carberators are well familiar with the leaf blowers. Once a year or every other year you should clean up your carb. During the winter season when your not using the blower, it is a good idea to put a 1/2 bottle of Stabil in the gas tank which will prevent carb gum-up while being stored.
You can remove the spark plug, put it back on the wire, lay the bottom of the plug next to a metal surface. Then pull the motor over while you observe for a good strong spark. If you have a good strong spark, then the problem is with the fuel.
If you have no spark, weak spark, or intermittent spark, then either the coil could be bad, plug could be bad, or you may even have a shorted kill switch.
Either no gas or no spark is your problem. Spark is easiest to check. If spark is good, remove and clean your carberator out thuroughly
Posted on Dec 31, 2010
Why my 2003 buick century runs fine for a couple days then starts overheating ,
if opening the bleed screws lets air out and you do if often ,that indicates a failing head gasket and compression gas is getting into the cooling system
have a compression test done to check for head gasket /cracked head
Aug 22, 2015 | 2003 Buick Century Custom
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
98 Buick Regal won't run unless hooked for a jump.
you may have a bad ground, or the ignition switch needs to be replaced.
Jul 28, 2012 | 1998 Buick Regal
In the morning cold weather, as i start the engine, when i press the gas pedal, the engine is almost going to die. Try to press/release and couple minutes later it is fine for the rest of the day. Tuneup...
This is a classic sign of clogged injectors. Run some cleaner. Use the bottle to about 1/4 tank instead of 20 gallons it says. If this hepls a little continue to use the fuel system cleaner for a couple tanks. You may need a repair shop to service them if there not clearing up.
Nov 20, 2009 | 2000 Chevrolet Silverado 1500
1995 Chrysler Concorde
the alarm is activating when he locks it and for some reason the key or fob isnt deactivating it..check the disarm switches in the door
Aug 11, 2008 | 1995 Chrysler Concorde
Truck starts, dies. truck runs good some days,bad the next
I had the same problem with My 1990 F150 300 6cylinder 4x4.....I cahnged all the same things you did, finally I sprayed a can of Gumout through the throttle body and it worked and ran great. Now I add fuel injector cleaner to the gas and a regular clean with the gumout and the problem has'nt come back. Good Luck to you and hope it works!
Aug 04, 2008 | 1990 Ford F150
86 bmw L7
I think your problem might be your fuel relay which is situated next to the fuse box in the engine compartment.
Jul 13, 2008 | 1986 BMW L7
Garden Logo
288 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
