Question about Johnny Lightning Monaco Motor Home Imperial
On my 2006 monaco diplomat the buzzer start beeping when you take the emegency brake off and put the trans.in drive..some times it may beep for five minutes,and other times it may beep for thirty minutes.one time after driving about four hrs.it started beeping and lasted for about one minute.sometimes it will go off in a few seconds...the sensor seems to be located under the dash on the drivers side,and will really be hard to replace.what can i do to solve the problem..thanks,willard eversole.
1 beep every five minutes, i have no oil ***** light on ever.
Is it the oil warning? Beeps can come from a number of areas. My door closed warning would beep when I braked. Seat belt intermittent, even your speed warning setting beeping once when over setting got me once. I didn't even know I had set it.
If the oil light comes on before starting, (as do all warning lights) and doesn't show up on the beep, it probably is not the source of the beep.
Cheers
Dave
Oct 24, 2014 | 2006 Ford Explorer Eddie Bauer 4x4
Warning buzzer on 2006 lincoln town car
Maybe post your question under automobiles.
Mar 18, 2014 | Computers & Internet
Which fuse for Warning buzzer on 2006 Peugeot 207
Go and check the rear left and right tail lights. take off connector and you'll notice that earth wire and pin is blown.
Jan 25, 2014 | 2006 Peugeot 207 1.6
1985 740 volvo
My guess is the seat belt warning buzzer.
Apr 06, 2013 | 1987 Volvo 240
Constant beeping while washing
This can be due to fault within the control panel output to the indication and buzzer. If the washer works without any issue and the cycles are correct, then it is best to remove the buzzer connections as the drive output transistor or IC could be intermittent and so works erratic.
Jul 03, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
I have a sterling diplomat 306 id,
Look at the right hand back corner of the bootlid recess, there is a very small steel spike sticking up which is a switch. Sometimes if the scooter goes over a sharf bump, the lid jumps slightly and the switch lifts momentary and puts the brake on. It thinks the lid has been lifted and goes into charging mode.
Switching the power on and off resets the system until the next sharp bump.
The switch is ajustable, or the bootlid needs to be pushed down harder before locking it.
I had this happen on my Diplomat 408i.
Hope this helps.
Regards,
Paul
Jun 01, 2012 | Health & Beauty
When I turn the key on it beeps 10 times and then pauses and beeps 5 times. The manual says that the five beeps indicate the manual freewheel lever needs to be put in drive. I did exactly as the manual...
The beep code will begin with 10 very fast beeps, followed by 5 slower beeps. The 5 slower beeps is your actual code. The beep code 5 is a brake fault.
The scooter may be in freewheel mode or there may be a short in the brake.
Make sure the scooter is in drive mode with the rear brake lever in the correct position. If that does not clear the fault you need to check the electromagnetic brake.
To check the brake you need a digital voltmeter. The brake should read 30 to 65 ohms when you read across the pins. You need to measure the resistance at each successive point on the harness because there are 5 connectors. While you are inspecting these plugs, check for corrosion, loose pins, broken wires, and pins not making good contact. Disassemble the front and rear halves of the scooter when you do this.
If all the resistance checks are good up to the controller plug for the brake, you have a bad controller. With that being said, I usually see a bad connection at the multiple points in-between. Sometimes the wires for the brake will melt at the connector at the controller.
Inspect these areas visually, removing the rear cover of the brake/motor/transaxle and the controller. An experienced tech should charge you under 1 hour labor for the diagnosis. You may be able to save some money by checking the obvious areas for unplugged or bad connections first.
The brake will cost about $250, the interface wiring and connectors about $50 and the controller is about $500. For this reason, you should invest in a good tech to diagnose the problem first, before proceeding with any hit and miss do it yourself repairs.
Including a second visit to install the new parts, labor cost should not exceed 2 hours total.
This is a very popular model so you should be able to find an experienced tech in your area.
Dec 23, 2010 | Pride Mobility Products Go-Go Elite...
LaCie
If your hard drive is equiped with a buzzer ... you can try to find that and remove it to stop hering the beep. Let us see how to find buzzer... The buzzer is round in shape, but not globe-like. it works like a small speaker. Usually it looks like a button cell or something like a black bolt. Caution; your hard disk may not have a buzzer...when it shakes, something on the hard disk may be getting scratched continuesly. This makes a beeping sound. If this is the case better we ignore it. If we try to lubriacte this will cause the drive to malfuction.
Aug 14, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Johnny Lightning Monaco Motor Home Imperial Logo
Top Johnny Lightning Toys Experts
ray gallant
Are you a Johnny Lightning Toy Expert? Answer questions, earn points and help others
