Question about Ovens
I have a Viking double wall electric oven, M# VED0207CSS. The upper oven needs a self clean locking mechanism, I'm an appliance repair man for 28 years, would anyone know if when I pull out this specific oven,teh self cleaning locking mechanism is accessible from the top panel?
  • Ovens Master
  • 5,370 Answers
Click this link directly to get full disassembly diagrams.If lower door is closed,then lower unit has to be disassembled,if upper door is got locked,then upper section has to be disassembled. Click this link directly to get section by section disassembly diagrams:--- http://technoanswers.blogspot.com/2011/01/how-to-disassemble-viking-electric.html ------------------ If the diagrams are not very clear then check out this links one by one for proper view:-- Link for control panel:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00001.png ------------- Link for door latch:-- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00005.png ---------- Link for door disassembly:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00006.png ------------- Link for cabinet disassembly:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00002.png -------------------------- This should help.keep updated.Thanks.Helpmech.
Posted on Jan 02, 2011
Why when i used the self cleaning option on my upper oven will it not heat anymore?
Good Morning James,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
I did the self clean on the upper oven. When the stopped cleaning it cooled down, but the door will not open. (Unlock)
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 15, 2010 | Viking VEDO205 Electric Double Oven
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
How long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Feb 11, 2010 | Viking 27" Professional Select Built-in...
Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
May 24, 2009 | Jenn-Air Electric Double Oven
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Oven remains locked after self cleaning
I ended up paying an independent appliance repair man $149.00 to fix my problem. However the "fix" also includes the fact that I can never lock the oven again.
Nov 22, 2007 | Viking 27" Professional Select Built-in...
Ovens Logo
1,559 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
