Fagor boiler code F1 comes up amd it will not light.
Fagor eco plus FA 15/20 boiler faults
Do you still make this boiler?
Dec 19, 2013 | Dishwashers
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
I have a Protherm 80e boiler which keeps going to the F1 mode
google your boiler it comes up with a manual go to page 26 it gives you 5 reasons why it goes to f1
Aug 16, 2017 | Water Heaters
Fagor F1-48W dishwasher won't fill
this must be a water flow problem to machine , id look real carefull at valves under sink or under floor of machine to see that there open and there are no kinks in hose connecting to it , other than that the one only other reason that it would not add water is that it thinks there's water in it already
Dec 21, 2012 | Fagor Dishwashers
Showing F1 on display boiler makes a thudding noise then goes to F1 mode. Smell of gas.
Hello
Sounds like a low water cutoff switch is stoping burner from lighting.
Check that you have at least 15psi of water pressure on the boiler guage.
Try to reset the cutoff switches.
Nov 08, 2010 | Heating & Cooling
Valliant combi boiler Fault Code F1 What does it mean
f1 means failed to fire check you have gas to bolirt and check water leval on boiler 1.5 bar
Aug 09, 2010 | Heating & Cooling
No instruction manual
The instructions are available in
http://www.fagor.com.au/manuals/dishwashing/versionw/FI-48W,%20FI-64W.pdf
Hope this helps. Please post a comment to say if you found this useful or not.
Apr 20, 2010 | Fagor 24 in. FI-48W Dishwasher
Fagor f1-48w
The machine won't go into rinse if the rinse isn't hot enough. Check the thermal trip hasn't operated and that the thermostat bulb us fully inserted into the pocket in the front of the boiler.
Jul 02, 2008 | Fagor 24 in. FI-48W Dishwasher
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
