Question about Compaq Computers & Internet
Where is the small battery - Compaq Computers & Internet
    Brigadier General:
  • 8,909 Answers
The position is dependant on the model number.
Usually it is underneath the keyboard.
Hope this helps.
Posted on Dec 31, 2010
How to replace old battery with new in a 2002 oldsmobile silhouette
Take note of any radio codes. If you don't know them, get a small or another 12v battery, a set of small jumper leads, connect the leads clips to the matching cables on the car at the battery. You are now supplying a small current in parallel. Using a buddy to hold the battery terminals away from the bodywork remove the negative first, then the positive. Remove battery and replace with new battery. Reattach positive terminal first then negative, then remove small jumper cables and it should have preserved your codes etc.
Nov 17, 2016 | 2002 Oldsmobile Silhouette
How do u change the battery in a gossip small ladies watch
  • Remove back
  • Locate battery and note how it is installed
  • Identify battery
  • Obtain replacement battery
  • Remove old battery
  • Install new battery
  • Check operation
  • Reinstall back
  • Set functions
  • Return to small lady
Oct 14, 2016 | The Watches
How do you change the battery on the leisurewise pro fitness exercise bike
Disconnect the small jack plug from the small display unit on the handlebars. Remove the display from the handlebars undoing the two small screws, the gently prise the front of the unit of exposing the small printed circuit board on which there are two button batteries ( LR 54 available from ebay or almost anywhere else ) Replace batteries and reassemble to Bike
Apr 08, 2013 | Exercise & Fitness
I brought a remote and put in 2 AAA batterys and it was small
what was small, the remote you brought or the 2 AAA Batteries? if the 2 AAA batteries are small try the medium size batteries. GOOD LUCK!!!!
Oct 05, 2011 | Televison & Video
How do I change out the batteries in my Sparco SPR02191 calculator
First a get cup or some sort of container to hold onto small parts.
Turn the calculator over on its back. You will need both a small phillips type screwdriver to remove the two small screws at the top. One that has been magnetized is best. Also you will need a small narrow bladed standard screwdriver to seperate the two halfs apart. Once you have removed the two screws and put them in a safe place it is time to open the case itself. Start near where one of the screws was and put the standard screwdriver in the groove between the halfs and gently start twisting it to pry the halfs apart. Work your way around the two halfs gently and slowly. There are plastic clips around the edge and they will slowly pop one after the other. Once you have the two halfs apart there is a small holder containing the battery. One side of the holder has a small gap. Slowly use your small standard screwdriver to push the battery gently though this gap from the far side. Mine had a GP189 button cell. You can go online and google 'GP189' and look for other rbatteries of this type. Same thing for putting the replacement battery back in. Just get it started with your fingers and push it in with the small standard screwdriver. If you don't have a small standard screwdriver a small dinner knife can be used to pry the halfs apart and anything small like that can be used to get the batteries in and out. Anything small of metal or bamboo comes to mind. As far as getting a new battery on the cheap try looking in 'Dollar Tree' type stores. If they don't sale the batteries themselves you can purchase a small generic calculator or any other small electronic and rob the battery from it. That's what I basically did in looking at other small calculators I already owned and robbing a battery from one of those. The very last step I took just before putting the calculator back together is noting the battery type and position and marking that on the back of the case with a fine tip sharpie.
Jun 20, 2011 | Sparco Products SPR02191 Calculator
Battery in the remote
some controllers have a small screw holding them together but most just snap together and have to be pried apart with a small flat head screw driver and inside is the small watch battery.
Feb 20, 2010 | 2005 Volkswagen New Beetle
Date/time screen always shows up upon startup. Does not remember date/time entered.
Your camera needs a small CMOS battery replacement which saves date, time and maintains these settings even when your camera is off. Look on to the sides of the camera, there will be a small rubber flap which has this battery. You need to replace this small coin-like battery. This battery is not the same as you always use/charge. If you can't locate the small battery, you will find more information in the camera Manual in troubleshooting or camera diagram.
Jan 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Cllock does'nt time when shut down ?
Most probably your CMOS battery needs replacing.
Jan 06, 2009 | Averatec 3200 Notebook
How do you change the batterys in hasbro cosmic catch ball game
The "push" button has a small hole on either side. there is a small screw at the bottom of each hole. Use a small philips head screwdriver. Once you have loosened the screws, this whole "block" of foam will come out of the ball and you will see the battery compartment.
Dec 27, 2008 | Cosmic Pet Hasbro Cosmic Catch Game
Info
  1. Using a small phillips head screwdriver, remove the six small screws off the back. Be careful not to lose the small screws.
  2. Using a small straight head screwdriver, insert it into one of the two slots at the top of the calculator and twist. The top of the calculator should pop open.
  3. Remove the back of the calculator.
  4. Using the straight screwdriver, insert it below the bottom of the two silver batteries and pop the batteries out.
  5. Replace the batteries with two new GPA76 batteries.
  6. Replace the cover and isert the screws.
Mar 26, 2008 | Texas Instruments TI-30XA Calculator
Computers & Internet Logo
14 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
