I have changed the bulb in my t.v as it was wearing out. switching back on the tv it shows a green light for 2 seconds then flashes red twice. model number is sony kdf-e50a12u
    Problem Solver:
  • 5 Answers
You haven't pushed the lamp housing in far enough. Take it out and push it back in. worked for me.
Posted on Sep 11, 2009
  • Dave Bond May 17, 2012
    Or haven't turned the locking lever far enough to right, there's a micro switch that keeps it off for safety unless bulb assembl is locked in properly.
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Feb 24, 2013 | Sharp Aquos Televison & Video
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Oct 03, 2011 | Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 26, 2008 | Audio Players & Recorders
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
219 people viewed this question
Top Televison & Video Experts
Electro Med Services...
