I bought a blueray player with wifi for my tv in the basment. My d-link router is upstairs in the family room. Would it be too far for a proper connection?
  • 1,719 Answers
Most routers have about 200m range. However, the actual range in real-time environment is much less. I think that your network would work fine. Also, based on my on-site experience, I suggest that you may relocate the router to another location depending upon your network environment. It has always helped me a great deal. Placing the router avoiding obstacles such as concrete pillars, walls, steel cabinets etc in the signal path have remarkable effect on range and overall performance of the network.
HOPE IT HELPS...Let me know if you need any further clarification/ assistance.
Don't forget to rate the solution if I could have been of any help!
CreativeTECH
Posted on Dec 31, 2010
How do I get NETFLIX on TV
You need a internet capable device a wwii blueray player or plug your computer into your tv .
Dec 12, 2014 | Netflix
I have a d-link 2750u wifi router with dual atntena..but connect in my badroom its near by wifi router i fonna show you in video with distan
Hi
Thanks for the video. I appears that you have concrete floors in your home. A couple of things that drasticly reduce wifi distance or signal strength is electrical fields caused by wiring in the walls and concrete walls or floors. Concrete is very dense and also has a lot of metal rebar in it for structural strength. This combination is very tough to penetrate with radio signals. The best thing you could do is either mount the router higher in the first room you showed so that it is at a level about even with the floor of the second level or add a repeater somewhere on the second floor. Mounting the router higher allows the radio waves to bounce around both levels without having to go through the concrete and rebar between them.
Jun 13, 2014 | Computers & Internet
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
Cant keep ipad2 connectd to netgear wnr1000 vs
Sounds like the Ipad is getting out of "readable" range of the WiFi signal. You might log into the router and change the channel to channel 1. If that does not work, try another channel. If no channels work, you will probably need a Wifi extender to get the signal upstairs and readable for the Ipad.
Jan 26, 2012 | NetGear WNR1000 Router
Wifi blueray player won't connect to the internet, just bought the netgear600 and am having problems
Most of the wifi blueray players will really say "wifi ready" meaning you have to buy an adapter for the wifi part to work at all. What blueray player is it?
Nov 28, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I BOUGHT A BLUERAY PLAYER NOW SAYS NO CONNECTION BOUGHT A BELKIN ROUTER SO WHAT DO I NEED TO DO TO GET THE ROUTER TO CONNECT TO THE BLUERAY PLAYER
Well first you have to connect the router to your modem for the internet and follow the steps in instructions to set up router. Make you are able to connect to internet on your pc. Then you will have to make sure that your blue ray has wifi built in or is wifi ready with the wifi adapter. if not you can run a network cable from the router to the blueray. You will then search fro a network connection on your bluray and connect it. Hope this helps, best of luck to you :)
Dec 27, 2010 | Belkin (F5D8231-4) Wireless Router...
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
