Question about Whirlpool Washing Machines
Lsr7233B How old is the washer? It has started to stop at the change of cycle and you have to manually restart. What will it take to fix the washer of should I be looking at buying a new one?
  • mpn2 Jul 08, 2008
    Please discontinue sending messages I am not interested in your services
  • 5,911 Answers
Post back with your COMPLETE serial number (located along the wash tub rim under the lid). The age is determined by the serial number.
Posted on Jul 08, 2008
Wash started cycle. Wife stopped it at beginning of cycle. Now washer will not start at at. Lid switch is good. Will not spin, rinse, restart wash, nothing, not even clicking.
Does unit have a reset button? If it has manual control for cycle did you try going clockwise to the start position and then restarting?
If she stopped the cycle by opening the door perhaps that switch is still stuck in an open position.
Aug 31, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a ATF7000FS1 washer that has been pausing the wash cycle on it's own. I will have to press the start/pause button during the cycle to restart. This happens several times during a wash cycle. How...
some machine will stop before spin its called crease guard if you are useing a low temp cycle its there to give you the option to stop your cloths wrinkling try another cycle
Nov 08, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have the model LSR7233B with the same problem as
What I would do is unplug the lid switch assembly from the harness and jump out the quick connect to see if that washer will run fine. Then replace the lid switch assembly. To do that you is gonna have to flip up the control panel. I have repair photos HERE
Feb 14, 2010 | Washing Machines
LSR7233B. Midway during regular wash it stops and
sounds like a bad timer.the part# is WPL285938,cost is $148.35.
Dec 11, 2009 | Whirlpool LSR5132PQ Top Load Washer
Have whirlpool LSR7233B top load washer. It fills and agaites but will not drain all the way and spins slowly on slowly on spin cycle
THE BELT THAT DRIVES THE DRUM MIGHT BE WORN, THE BELT IS NOT UNDER A LOT OF STRAIN WHEN WASHING AND MAY WORK FINE BUT WHEN IT GOES INTO THE SPIN CYCLE THE WEIGHT OF THE CLOTHES AND THE WATER WILL CAUSE THE BELT TO SLIP . I WOULD START THERE FIRST
Aug 23, 2009 | Whirlpool Washing Machines
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
359 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
