Question about LG WM2277H Front Load Washer
I want to clean the soap and softner holders I need a manual
  • 876 Answers
Http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
I clean mine with plain hot water and a rough towel. Then I fill the dispenser with hot water and run a light wash cycle.
Posted on Dec 31, 2010
My LG washer machine will not rinse thru the softer section in the cup, what can I do?
then the solenoid is not actuating to allow water into drawer. take top off, very easy, two screws in back, pull back, lift off. follow hose from softer cup to little round device/solenoid. check wiring. check hose, tho you would know there was a problem with hose, because you would see a water leak. replace solenoid. hope this is the issue. good luck.
Mar 02, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Inside washing machine
I'd pour in white vinegar and let it soak. Flush with hot water. You'll probably have to repeat. Once it's clear, you might consider a detergent that is residue-free (Charlie's Soap is an example) so that you don't need fabric softener.
Aug 11, 2014 | Washing Machines
How do I gat fluff out of shampoo cleaner
Don't use a shampoo cleaner. All soap is a Lubricant so instead of using a Shampoo try IVORY soap or Irish spring Or that HUGE old school bar of soap its Light GREEN & used to help poison ivy =you may have to soak the Bar of soap over night but a water softner keeps soap from creating bubbles & a water softner is only salt added to water so add a table spoon to 1 gallon to IVORY or DOVE or IRISH SPRING it cant hurt its only soap
Jul 26, 2014 | W87-Rh-P Rapide Ultimate Clean Upright...
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
I am getting dirty oily marks on washing.
Hi, assuming this is a frontloader? have you tried applying a hot wash cycle with out any clothes in the machine? You may want to check the condition of the detergent holder for any harden frabric softner, washing powder that could be blocking the new detergent from entering the machine, also examine the front door of the machine and clean away any heavy soap sud residue that the machine collects during normal operation, also if you have a user manual you may want to check for any added filters that the machine incorporates, it may be something as simple as cleaning the filter, hope this helps.
Apr 30, 2011 | LG Washing Machines
Kenmore 70 series, leaves browb lines on clothes. is there cleaning procedure for the washer?
It could be coming from your fabric softner. I know when I use liquid fabric softner I get oily looking stains on clothes. I no longer use liquid softner. I also use Dawn dish soap in my washer. I use Dawn instead of any other stain removers. Dawn dish soap works on everything.
Dec 02, 2010 | Kenmore Washing Machines
Dispenser is full of water. Hard to put back pieces.
I was getting frustrated when I could easily take out the pieces, but couldn't put them back. The actual slide out holder comes right out with a little bit of manouvering and then you can put the pieces back and wash and rinse any build up in the containers. Yay !!
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Machine wont take conditioner
hi there remove soap drawer and softner compartment lid clean throghly both hole and tube inside and out failing that clean soap box lid inbside with bottle brush at worst you may need to replace the soap box lid assy
hope this is of some help
Jan 11, 2008 | Zanussi FJS1225W Front Load Washer
Fabric Softner section won't fully drain....
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2007 | LG WM2688HWM TROMM SteamWasher
LG WM2277H Front Load Washer Logo
55 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
