Question about Epic 425 Mx Treadmill EPTL88105 !
Our treadmill is locked into the 12 degree ramp mode and will not go down. We have tried the reset button, tried turning off and reset, but it is still locked and will not go down. What could be the solution?
  • 31 Answers
The incline sensor is probably defective and let the incline motor physicall jam against the stop. About 50% of the time a new sensor will cure the problem; otherwise, a new motor with the sensor is the cure. Either way the incline motor must be removed to address the problem and I would reccomend leaving this to someone with experience as you could possibly injure yourself trying to attemp this without the proper knowledge. The weight of the teadmill is on the incline motor and that is where the risk is.
Posted on Jan 15, 2011
When my daughter goes down a ramp the wheelchair tilts forward and the back wheels are off the ground! Why is this happening?
ramp too steep and not made to a safety standard
person too high in chair
person too far forward in chair
front wheels not positioned far enough forward
carer not paying attention to the ramp and possible risks
talk with disability persons equipment retailers as they have a good idea of the risks involved with wheel chairs and can advise you on how to overcome the problem
Jun 21, 2016 | Health & Beauty
My treadmill is stuck on incline 12 and wont move up or down tried all the resets?
Go into engineering mode by pressing the stop and speed up button at the same time while inserting safety key. Once in mode, press the stop button once more then press the plus incline button. the incline should calibrate itself. If not then you might need a motor control board.. I have some in stock, shoot me a message if needed
Mar 10, 2015 | Exercise & Fitness
C2250 treadmill incline recalibration - incline goes up, not down
Plug the power out and plug it back in after a count of 50 could be that it needs to be reset .then plug back in the power and see what its doing if no luck go to manual and look for reset
Jan 06, 2014 | Nordic Track Exercise & Fitness
Incline stuck at 12
please follow this steps and fix it. Merry Christmas
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 18, 2013 | Nordic Track NordicTrack - E 7.5
I bought a second hand Proform 14.0 CE elliptical. The incline is stuck at about 20 degrees. The incline ramp moves slightly while trying to calibrate but remains about 20 degrees. The display shows that...
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Oct 24, 2013 | Exercise & Fitness
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    My c2200 treadmill will not reset or operate other than the incline from 4 degrees thru 12 degrees. fan nor tread will operate. Pulse sensor does work. is there reset instructions
    This is dinesh from AADHI FITNESS SERVICE CENTRE...
    Search for the details in justdial india...
    Can we come to ur place and check the machine... My contact no is 9986202487
    Jul 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
    My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
    Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
    LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
    The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
    Jun 11, 2010 | Tunturi T30 Programmable Treadmill
    Where is the reset button on my Proform 750 CS? The ramp won't move up or down.
    Check your manual, if you don´t have one, ask here to find it:
    manualfox.com/link/proform.htm
    Jan 08, 2010 | Proform iLog 750 Treadmill
    Epic 425 Mx Treadmill EPTL88105 ! Logo
    653 people viewed this question
    Top Epic Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Matt Olenzek
    Matt Olenzek
    Colin Stickland
    Colin Stickland
    Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
