Question about IBM ThinkPad R30 2656 Notebook
Have replaced CMOS battery. keyboard works OK On reboot ......... warning IRQ not configured press F1 for bios setup utility Press F1 and nothing happens.
  • 942 Answers
Try to turn off the laptop. Remove the cables and battery on it. Then press and hold the power button for 8 secs. Then reinsert the cables and battery on it. Turn it on and press F2 instead of F1 for BIOS setup....
Posted on Dec 31, 2010
Durabook T7M no access to BIOS
Keep trying until the keyboard is ID'ed. Unplug, remove battery, plug in, reboot. Is there a reset button?
Jan 25, 2013 | Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Hi, I really need your help, please help me. I get this CMOS Settings Wrong CMOS Memory Size Wrong Press F1 to Run SETUP Press F2 to load default values and continue ... and my keyboard doesn't work ...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Oct 04, 2010 | Asrock P4I45GV R5 Motherboard
Cannot seem to find how to enable the sata ports. I've tried all the solutions suggested with no good outcome.
With the SATA drive properly attached to the cable, try clearing the NVRAM (CMOS). By clearing the NVRAM (CMOS), the system will redetect all the installed hardware including your new drive. Just follow the procedure I have outlined below. After the clearing of the NVRAM (CMOS) you may get a warning at boot up about the Diskette Drive if you do not have a floppy drive installed in the system. If that happens, just go into the BIOS Setup and disable the option for the Diskette Drive. The error message will be gone on the next reboot.
  • Reboot system and enter the BIOS Setup by pressing F2.
  • Turn on Caps Lock, Scroll Lock and Num Lock.
  • Press ALT + E then ALT + F (should hear beep) then ALT + B
If you need any further assistance please feel free to contact me again.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 13, 2010 | HP Compaq Presario SR1200NX (PN211AAR) PC...
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
Can't get into the bios for a presario 4716
This is what the Compaq site had to say about the BIOS utility for your system (Source: Compaq): • • • •You may have difficulty accessing the BIOS Setup utility screen, because you must press a specific key(usually F1) very quickly before the Windows screen appears. If you do not enter the BIOS Setup screen on your first try, repeat the following steps until you are successful.
To open the BIOS Setup screen:
1. Turn off the PC and wait about 5 seconds.
2. Turn on the PC.
3. When the first screen appears, press the F1 key on the keyboard. (You can press the key more than once.) The BIOS Setup Utility Main menu appears.
NOTE: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
4. Use the keyboard to navigate through the menus.
You may need to remove the battery and then back in.
Jul 21, 2009 | Computers & Internet
Bootup Problem of Dell PE6650
Your NVRAM was corrupted (probably by a dead CMOS battery) or your hardware configuration has cnaged (deah boot disk, etc). Enter setup to see if the date/time has reverted to a previous date. If so, the CMOS battery needs to be replaced and the BIOS reconfigured for the server. Otherwise, check to ensure that your disk configuration is correct. If the battery is not dead and your disk configuration is incorrect, you may have a bad hard disk.
Jun 05, 2009 | Dell /Poweredge 6650 BackPlane 2+3 Board...
**** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time
Hello
Please reset cmos to factory defaults.
Then enter the bios setup and configure it and save changes.
Apr 20, 2009 | Computers & Internet
Plug & Play Configuration Error
this may not be your ethernet card that is causing the fault, it is probably a flat cmos battery (CR2032) disc shaped battery normally close to the memory slots. This will need to be replaced, it's a simple job, just remove side panel of tower and flip the battery out and replace, probably cost $3.00. You will then be prompted on the next boot up to press f2 to set the date and time and then save and exit again for a reboot
May 29, 2007 | Dell Dimension 8200 PC Desktop
IBM ThinkPad R30 2656 Notebook Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
