Question about Dryers
Dryer vent was just cleaned but dryer is not giving out hot air
  • 1,772 Answers
Sorry to read about your problem.
Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Gas dryer will heat but won't dry clothing
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, and recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance.
Oct 23, 2015 | Dryers
Air will not come out the vent on my maytag dryer
Check the filter and give it a clean. That could be the problem as if there is no where for the air to go it can't come out.
Sep 28, 2014 | Maytag Dryers
Dryer IS getting hot and it IS tumbling. However the clothes are not drying? I already checked for lint in the vents and cleaned the little bit in them. There also seems to be moisture inside the dryer...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 14, 2011 | Maytag MGDB400VQ Dryer
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
Maytag dryer is getting hot,but taking a long time to dry clothes.
Check your dryer vent see if air is coming out if dryer is getting real hot its dangerous have dryer vent cleaned
Dec 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My hotpoint dryer takes hours and hours to dry clothes?
clean the vents as it is an air restriction, first take off the vent house run dryer and feel for hot air, if no or little hot air then then inside of the dryer needs to be cleaned, now if you run the dryer with the hose off and it drys like it should then the vent hose needs cleaned/unrestricted. Hope this helps Tim
Nov 07, 2010 | Hotpoint Dryers
The dryer does get hot but takes a very long time to dry a normal load of clothes. What I noticed is that the top right hand corner of the dryer gets scalding hot during the cycle. It worked fine before I...
It sound like you have a venting problem. The air from the dryer is probably restricted by either a clogged exhaust hose or duct work in house or a stuck vent flap where air blows to the outside. If your vent goes straight up to the roof, something may be blocking the exit or the whole line may be clogged. Also check for a kinked flex hose that attaches to the dryer. If blockage is in wall of house, there are vent cleaning companies that can clean out the line.
Feb 04, 2010 | Kenmore 84052 Dryer
Just bought a new HE5 dryer three days ago and used it for the first time---the sides of the HE5 dryer are extremely hot (could burn hand), is that normal and what could be the cause?
check the vent line,could be clogged with lint if you never cleaned it,you should clean out your dryer every year by taking off and cleaning out the duct that the lint filter slides into,vac out the inside of dryer and clean out the vent line,if it's a long run from the wall to the outside vent hood blow it out with a leaf blower,go outside and make sure the air is blowing out with force,all a dryer does is move air and if something is blocking the air flow the dryer will get hot,you'll start blowing thermostats or the thermal fuse because they are safety switches so if the dryer does run to hot they pop and shut down the dryer so hopefully you don't have a fire or damage the dryer
Jan 10, 2010 | Kenmore HE5 Electric Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
