Question about Samsung HP-R5072 50 in. Plasma HDTV
My television says check fan no. 1 and it shuts off by itself. whats the problem?
  • Samsung Master
  • 5,138 Answers
It means the Fan is either Defective or has Dirt and dust built up on Fan and Fan needs to be Cleaned.
Posted on Dec 31, 2010
Hitachi tv turn off by itself when i get hot, how do i fix it?
Check for any air path obstructions and see if the fan is working, if not it needs replaced or checkd out. You can try and put a fan behind the unit to keep it cool this will sometimes work but the main reason is the set is getting to hot and it shuts itself down to protect itself from a failure.
Aug 14, 2011 | Hitachi 50SBX78B 50" Rear Projection...
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
Error Message: Condition 1
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
a repair of this unit is possible.
Regards
May 12, 2010 | Fujitsu Plasmavision PDS-4214 42 in....
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
Check Fan No. 2 Error Message
The DMD board you installed is bad. It senses the detection line from the fan and generates the error code. Try installing the old DMD board.
Mar 15, 2010 | Samsung HL-S5086W 50" HDTV
My televison keeps turning off after being on for about 2 min. bulb has already been replaced.
Sounds like it is heating up on the inside. If you take the back cover competely off you will see that you have 4 fans on the inside, 2 big fans one on each side, one to cool the lamp and either 1 or 2 little fans which are located on the electrical box on left side and sometimes one that is mounted behind the DMD Board which is located behind the engine assembly. Because it is shutting down it tells me that the fan to cool the lamp is faulty. What happens is the fan cools the lamp, if the lamp gets too hot the television shuts down to protect itself from damage. Because AKAI parts are extremely rare to find I recommend not attempting to even turn on the television until you are able to replace the lamp cooling fan. If you see it is spinning it doesnt always mean that it is working because it may not be spinning fast enough. Good luck in finding a fan for it.
Feb 20, 2010 | Akai PT50DL24 Television
The TV shuts off by itself and then comes on 30 seconds later, it keeps doing it over and over. It did stay on for a few hours last night but then kept shutting on and off again.
First CK Fan that cools Lamp if it stops running then Lamp will shut off Fan is either defective or Ballast Board needs to b replaced But if you have never replaced Lamp it could be the Lamp CK Fan first Go to website Encompass Parts Distr. they have everything you need and Parts List as well as a service manual for your TV 1-800-638-3328
Nov 30, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
TV Keeps turning off
i'd check the power supply or the fan. the tv will shut itself off if it gets too hot or doesn't register the fan as working, not to mention need full juice to run....
Nov 20, 2008 | TruTech PLV1615T 15 in. LCD Television
Samsung HP-R5072 50 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
