2001 Toyota Highlander Logo
Posted on Dec 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AF sensor malfunction bank 2 sensor 1 - 2001 Toyota Highlander
ZJ Limited
Level 3:
  • Toyota Master 17,989 Answers
  • Posted on Dec 31, 2010
ZJ Limited
Toyota Master
Level 3:
Answers
17989
Questions
0
Helped
14454441
Points
60858
P1155: Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
The sensor is on the Bank 1 throttle body with electrical connection. Its a delicate sensor. Unscrew it from the throttle body and check if its dirty, spray it with electronic cleaner with care. If its damaged, just replace it.
If its not rectified, the car computer may default the air temperature to 20 degC and the air flow will not be correct and may have the following effect:
1. You might have difficulty in winter startups
2. Loss fuel efficiency (air/fuel ratio is messed up) / NO x problems/failed emission test/prematured catalytic converter replacement etc.
An Air Fuel Ratio Sensor is also known as Wide Range Oxygen Sensor.
Bank 1 Sensor 1 is mounted in the exhaust header before the Catalytic Converter (CC). The ECU uses the signal from the AF sensor to adjust Air/Fuel ratio. On V6 and V8 engines there is a second AF Sensor in the other header. (Bank 2 Sensor 1).
After the CC there is a narrow range O2 sensor called Bank 1 Sensor 2. It monitors the CC. If there are two CCs there is a second O2 sensor (Bank 2 Sensor 2) The AF Sensor draws about 3 amps so check connections. The heater is a resistor between the B+ and HT terminals of the plug. On V engines there is also a AF relay to check.
Keep us updated.
Anonymous
Level 2:
Sergeant:
  • Expert 242 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
242
Questions
Helped
114982
Points
766
Common problem, this bank and sensor are located in front by the radiator, if you are the one to perform the repair, when you crack the sensor open spray w40, then continue getting it loose, some times jams and damage threads in the exhaust manifold.
Often when the vehicle has lots of miles, there is a need to replace both af sensors, if you replace af bank 1 today, the computer sees a healthy signal and compares the readings to the other old sensor, then sees the difference and sets a code for the other sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
I am workimg on my 2000 nissan quest. it cranks and turns over but will not start. it is throwing codes P0340 twice and P0325. we replaced the distributor cap and rotor and still nothing. probably goi
P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor) -Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit (Bank 2) -Circuit Malfunction
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335 Crankshaft Position Sensor -Circuit Malfunction
P0336 Crankshaft Position Sensor -Range/Performance
P0337 Crankshaft Position Sensor -Low Input
P0338 Crankshaft Position Sensor -High Input
P0339 Crankshaft Position Sensor -Intermittent
P0340 Camshaft Position Sensor A Circuit (Bank 1 or Single Sensor) -Circuit Malfunction
sorry would a play with this to know for sure ,check the wiring plugs onto the sensors to make sure their not full of oil or corroded
Where is the bank 1 sensor 1 air flow sensor located on a 2000 toyota avalon?
Sensor diagram for a 2000 toyota avalon and list of Pcodes dbd372cc-f8f3-49ef-b0c2-2adab46c4182.jpg 8fc069a5-bedc-447d-a1ef-4335798a0a0f.jpg
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit Malfunction
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder #1
P0202 Injector Circuit Malfunction - Cylinder #2
P0203 Injector Circuit Malfunction - Cylinder #3
P0204 Injector Circuit Malfunction - Cylinder #4
P0205 Injector Circuit Malfunction - Cylinder #5
P0206 Injector Circuit Malfunction - Cylinder #6
P0207 Injector Circuit Malfunction - Cylinder #7
P0208 Injector Circuit Malfunction - Cylinder #8
P0209 Injector Circuit Malfunction - Cylinder #9
P0210 Injector Circuit Malfunction - Cylinder #10
P0211 Injector Circuit Malfunction - Cylinder #11
P0212 Injector Circuit Malfunction - Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0291 Cylinder #11 Injector Circuit Low
P0292 Cylinder #11 Injector Circuit High
P0293 Cylinder #11 Contribution/Balance Fault
P0294 Cylinder #12 Injector Circuit Low
P0295 Cylinder #12 Injector Circuit High
P0296 Cylinder #12 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1 - Misfire Detected
P0302 Cylinder #2 - Misfire Detected
P0303 Cylinder #3 - Misfire Detected
P0304 Cylinder #4 - Misfire Detected
P0305 Cylinder #5 - Misfire Detected
P0306 Cylinder #6 - Misfire Detected
P0307 Cylinder #7 - Misfire Detected
P0308 Cylinder #8 - Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1 - Circuit Malfunction (Bank #1 or Single Sensor)
P0326 nock Sensor #1 - Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1 - Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1 - Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1 - Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2 - Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2 - Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2 - Circuit Low Input (Bank #2)
P0333 Knock Sensor #2 - Circuit High Input (Bank #2)
P0334 Knock Sensor #2 - Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal "A" Malfunction
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B" Malfunction
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction P0441 and/or P0446
2002 toyota avalon engine check light on P0078 and P007C
P0050 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 1)
P0054 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 2)
P0055 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 3)
P0056 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 1)
P0060 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 2)
P0061 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 3)
P0062 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector -Range/Performance
P0066 Air Assisted Injector -Circuit Malfunction or Circuit Low
P0067 Air Assisted Injector -Circuit High
P0068 (MAP) Manifold Absolute Pressure /(MAF) Mass Air Flow - Throttle Position
Correlation
P0069 (MAP) Manifold Absolute Pressure / (BARO)Barometric Pressure Correlation
P0070 Ambient/Outside Air Temperature Sensor -Circuit Malfunction
P0071 Ambient/Outside Air Temperature Sensor -Range/Performance Problem
P0072 Ambient/Outside Air Temperature Sensor -Circuit Low Input
P0073 Ambient/Outside Air Temperature Sensor -Circuit High Input
P0074 Ambient/Outside Air Temperature Sensor -Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit Malfunction (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit Malfunction (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 2)
Air sensor check engine light
Ok as a guess that you have a SUV and you have different air faults. if you are a DYI'er go to an auto parts store and get an error code tool. Harbor freight for $30-50. Hook it to the car and find out which sensor is it calling for. Note, you can reset the check engine light on most tools that are not the cheapest.
P1130
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135
P1150
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155
My 96 nissian maxima turns off when driving down the road i try to turn the key ,lights in dash on horn blows but will not startcould it be alternater ,or what how does the 02 sensor go by functioning ...
As of 1996,all cars sold in the US were required to have an OBD-II computer interface port.
You may want to go to Advance Auto Parts, AutoZone, or Pep Boys, and get a free read
of the code(s) that you computer may be posting to help with your diagnosis.
The code coming from your vehicle's computer may be one or more of:
P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Note: "Bank 1" is the side of the engine with cylinder 1. "Bank 2" is the other side.
P0300 - Random/Multiple Cylinder misfire detected
P0301 - Cylinder 1 misfire detected
P0302 - Cylinder 2 misfire detected
P0303 - Cylinder 3 misfire detected
P0304 - Cylinder 4 misfire detected
P0305 - Cylinder 5 misfire detected
P0306 - Cylinder 6 misfire detected
P0307 - Cylinder 7 misfire detected
P0308 - Cylinder 8 misfire detected
P0313 - Misfire detected with low fuel
Maximas with the VE30DE and VQ30DE engines use a distributorless ignition system that is controlled by the Engine Control Module (ECM). The ECM receives a signal from the crankshaft sensor (the CPS - Crankshaft Position Sensor), and processes the signal based on inputs
from other various engine sensors, including the Oxygen sensor.
(this is the role of the O2 sensor in ECM operation).
Then the ECM sends signals to each of the individual coils in the proper firing order.
This system is more efficient than a distributor, and has fewer moving parts. The high voltage coils are directly attached to each spark plug, allowing a higher energy spark within the cylinder. A high energy spark means a faster, more thorough burning of the air/fuel mixture, which produces more power and lower emissions.
SECONDARY SPARK TEST - works for all cars, including Maxima.
1. Remove the spark plug.
2. Install the spark plug to the ignition coil/coil pack, then attach the coil wiring.
3. Ground the plug at a good ground location on the engine.
4. Crank the engine and check for spark.
5. If spark occurs, the ignition system is functioning properly.
6. If no spark exists, test the ignition coil/coil pack, power transistor and related wiring.
HEI Ignition Spark test - works for all cars, including Maxima.
The next level test you may want to try is a HEI (high energy ignition) spark tester kit. Cost is
about $30 at most auto parts stores. Harbor Freight Tools sells a chinese equivalent for about $16.
Place the spark tester on each of the spark plugs, and watch as the little light in the tester will
light up each time the spark plug is fired by the computer. You can actually see weak or
intermittent sparking as the motor runs - you can tell by the relative strength of the light as
you compare the intensity and duration of the light across all 6 cylinders.
If your problem were the alternator (or its built-in voltage regulator), your battery would not be
getting a proper charge, and you
wouldn't be able to start the car after a drive, since the battery would have been drained during the
drive - normally, the alternator will both charge the battery and run all electrical
features of the car during a drive.
To test your alternator, place your DMM (digital multimeter) across the battery terminals while the
car is running - it should read 13.5VDC to 14.5VDC. With the car off, you can test your battery
voltage with the same DMM - it should read 12.65 VDC (for a fully charged battery).
Alternatively, you can take your car to Advance Auto Parts, AutoZone, or Pep Boys, and they'll
attach their "charging system tester" to your car and give your car a nice test for free.
I do this with my customers' cars just to get that nifty printout of the problem. Its nice
to show a vehicle owner somethng in black & white when I'm recommending a new charging
or ignition system component (some of which can be a bit pricey).
Im getting code P2253 on my 04 Saturn vue with 3.5l V6. Anyway to tell which O2 sensor it is? Thxs Bill
P0804 is the highest OBD-II trouble code.
Here's your Oxygen sensor codes.
4helpful
I have a p1155 error code on a 2002 toyota highlander. what should i do?
P1155: Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) The sensor is on the Bank 1 throttle body with electrical connection. Its a delicate sensor. Unscrew it from the throttle body and check if its dirty, spray it with electronic cleaner with care. If its damaged, just replace it. If its not rectified, the car computer may default the air temperature to 20 degC and the air flow will not be correct and may have the following effect: 1. You might have difficulty in winter startups 2. Loss fuel efficiency (air/fuel ratio is messed up)/NOx problems/failed emission test/prematured catalytic converter replacement etc. CLARIFICATION An Air Fuel Ratio Sensor is also known as Wide Range Oxygen Sensor. Bank 1 Sensor 1 is mounted in the exhaust header before the Catalytic Converter (CC). The ECU uses the signal from the AF sensor to adjust Air/Fuel ratio. On V6 and V8 engines there is a second AF Sensor in the other header. (Bank 2 Sensor 1). After the CC there is a narrow range O2 sensor called Bank 1 Sensor 2. It monitors the CC. If there are two CCs there is a second O2 sensor (Bank 2 Sensor 2) The AF Sensor draws about 3 amps so check connections. The heater is a resistor between the B+ and HT terminals of the plug. On V engines there is also a AF relay to check.
1helpful
More 99 cougar problems
there is a fuse for the o2 heaters if one of the sensors blew the fuse they will all be out
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
