Question about Goodman GMS90703BXA Heater
Our heat will not go above 71, Even if you turn it to 80 it will not go above 71 it will run and run. What do you think is going on.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
If you have changed, or cleaned your filters, you may have a gas flow or gas control issue.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
Mar 21, 2017 | Coleman Heating & Cooling
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
My American Standard Furnace light blinks 3 times stops and blinks 3 times again and so on.
Look inside of service panel for trouble shooting codes and solutions
Feb 13, 2016 | Heating & Cooling
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
2006 Chevy Cobalt. My power steering goes out.
It sounds like the power steering motor is overheating pre maturely. Changing the motor should take care of the problem. What really happens is the motor reports to the power steering module that it is over heating and the module is shutting power to the motor down, the motor is actually no overheating.
Feb 02, 2010 | 2006 Chevrolet Cobalt
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Goodman GMS90703BXA Heater Logo
47 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
