Question about Dishwashers
Bosch dishwasher model sgs43c02gb/35.no lights on front panel will not run but power getting to machine
jsrock516
  • 5911 Answers
SOURCE: Power to dishwasher and will not run
Check your thermal fuse. It will be inside the control panel, clipped to the control board somewhere. It's usually a white plastic square piece with two wires connected to it. The fuse should read a short. If the fuse is blown, you will need to replace it. If the fuse reads good, I would suspect you have a control board problem. Make sure you secure power to the dishwasher BEFORE you take any resistance checks, however. Even if the fuse is blown, you could still have live voltage on one side of the fuse. If you cannot find the fuse, there should be a tech sheet with wiring diagrams inside the lower kick plate below the door. This could be a tremendous help you as well. Let me know what you find.
Posted on Jul 14, 2007
  • 1003 Answers
SOURCE: Stuck on agent
REPLACE TIMER
Posted on Jan 18, 2008
  • 54 Answers
SOURCE: How to remove bottom panel on front of Hotpoint model HDA 465-01 Dishwasher
two different models one is lean it back two screws hold the complete base on and you just twist the pump off. the other you can access the pump from below the internal filter on the left one torx screw and you can see if there is anything blocking the pump. regards
Posted on Feb 12, 2008
SOURCE: asko dishwasher model 1475
Have the same problem with our asko 1475. In the past, we would disconnect the dishwasher and when we reconnected the power, it ran fine. This time it isn't helping!
Posted on Jul 12, 2008
mark_37388
  • 100 Answers
SOURCE: My Bosch Dishwasher cycle runs for 2 plus hours!
If this unit is running for a long time it is because it is still try to heat the water temp up it is eather the control board or the heater.
Posted on Mar 28, 2009
Dishwasher stopped working. No problems prior to this problem. No lights come on in the control panel. Using a multimeter I've proved that power is getting to the switch on the door, and from there to...
Some Bosch models have a switch that stops the dishwasher from running when there is a leak. The water collects in the bottom of the machine. Give it a check.
Sep 12, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
The start button will not stay pushed in
Hi
The start button, tends to fail on some Bosch Dishwasher models. The spring mechanism fails.
You can order the ON/OFF switch and replace it.
You need to disconnect the machine from its power source and open the control panel via hex screws. You may also need to open the front panel screws to get the top panel off.
Bosch dishwashers can be tricky and when you open the panel you many need to undo some latch tabs to get to the on/off switch.
Note the wiring on the switch before replacing.
If you thinks this solutions helped, please give 4 thumbs up.
Sep 21, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Hi I have an Bosch SGs43c02gb/35 and it does not drain all of the water out when it has finished the cycle, I have cleaned the filters out which were relatively clean and run it with a dish washer cleaner...
Hello
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Aug 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch dishwasher model classxx maxx freedom performance sgs43co2gb/35. the machine when turned on doesnt stop,so i checked the control panel and there was a black ring of soot,before i purchase a...
i think your model was part of the recall and the repair is free to fix call bosch and they will take of ity. they need to know the model asnd serial number to know if it is one of the recall
Mar 08, 2010 | Bosch Dishwashers
My Bosch dishwasher won't shut off. The timer says "1" forever and when you open it there is about an inch of SOAPY water still there.If you press start it goes to "13" and again counts down to "1" and...
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Feb 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher sgs43c02gb cycle problem.
I found the problem for pump noise & water in bottom. The dishwasher hose connection under sink had small plastic piece stuck in narrow elbow
Jan 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
Pump continues to run
make sure you dont have water sitting under dishwasher in tray. it can cause pump only to run. If there is water in bottom, look under water valve, there is a float-is it surrounded with water?
Jan 01, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
Aug 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
Owen Barnes
