Question about Acu-Rite Acurite Wireless Weather Thermometer 604
What does HH.H mean, it keeps beeping at me - Acu-Rite Acurite Wireless Weather Thermometer 604
What does HH MEAN? How can I fix it on SPC 1003 atomic clock?
HH is usually a placeholder for the hour. Are you trying to set it manually?
Jan 10, 2018 | Home
Balboa panel on Viking aurora hot tub reads HH and then changes to SA when I turn on jets. Then back to SA thenHh. sA sensor just replaced and not fixed
Hello Christine.
As a warranty technician for both Viking AND Balboa, I think I can help.
SA is telling you that sensor A is defective. You already know this. But it can also mean that the wire is defective or the circuit board itself has failed.
HH means that there is a high temperature problem... or a sensor problem... or some other problem that is in that logic process.
The HH in addition to the SA points to a defective sensor.
First, turn off the breaker.
Second, reverse the two sensors at the circuit board by unplugging them and re-plugging them into the opposite jack. A into B and B into A.
Turn on the breaker. If you have a defective wire or sensor, it will now tell you that Sensor B is defective.
If it repeats that Sensor A has failed, then the issue is your board.
It is always a good practice to replace both sensors together to prevent these types of problems.
If it looks like the board is the problem, call us at 660-263-0984 and I can help you beyond this.
Dec 20, 2017 | Pool & Spa
What does HH on the outside temp mean on Model 513-1311OT?
HH means that the temp is over the highest reading that it is specified for. That means either the sensor is bad or it is in a very hot place. The maximum temp for that sensor is 122 degrees
May 28, 2015 | Measuring Tools & Sensors
Set time on Ben Sherman R424
Press and hold the top right button till it beeps. Then press the bottom left button to scroll throught the hh:mm:ss, use the top buttons to increase or decrease the number. Finish by pressing the bottom left button until you cycle through back to the time display.
Mar 27, 2011 | Watches
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
What does hh.h mean on display
I'm assuming it just stands for "High Humidity". It wasn't raining at the time, but it sure had been earlier, so perhaps if it's over some number (like 90%), it just says "HH".
Nov 01, 2010 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
Tempstar Door model keeps overfilling
The sensor is a plastic pipe (vacume) / and a ajustable switch. The rise in water causes the air pressure in the pipe to increase and at the set level this stops the water inlet valve. You could disconnect the pipe and blow into it slowly and should hear the switch click. Most faults are the plastic sensor pipe blocked / obstructed and or the switch terminals (inside switch) burnt. This means that the switch must be replaced and should be set for the correct water inlet.
Jan 21, 2010 | Jackson 25 in. TempStar HH Free-standing...
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
221 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
