Question about Vornado VH2 Compact Heater
The thermostat on my Vornado room heater Model VH2 keeps clicking on and off rapidly. Can I replace the thermostat?
SOURCE: My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Posted on Nov 20, 2008
directcurent
  • 59 Answers
SOURCE: The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
Posted on Jan 19, 2009
directcurent
  • 59 Answers
SOURCE: I have a Vornado VH2 portable heater. The fan has quit working.
generaly a problem like this ocures because of gummed up bearings
1.take apart heater
2.remove fan
3.wipe of bearings
4.lightly oil bearings and shaft around bearings ## TO MUCH OIL COULD POSE A FIRE HAZARD :0
5.asemble
6.test
directcurent
  • 59 Answers
SOURCE: Vornado VH2 stopped working. on/off not functioning
if it is a rocker type switch replace the swich
IMPORTAINT make shure switch it is replaced with is rated at 15Amps
SOURCE: Vornado VH2 heater appears to switch on, but fan
For some reason the re-set system had clicked off. Unplugged the unit for a while, and when plugged back in it was working once again.
Posted on Dec 24, 2009
My Vornado VH2 heater stops heating several moments after switching on. The fan runs but no heat. The heating elements never get hot but all the wiring appears to be firmly in place. The tilt shutoff...
A big problem with these heaters ans well as others is the motor driving the fan. The bearings get stiff from dirt and do not spin fast enough activating the over temp device of the heating element. Check the motor out by placing the unit in fan mode them pull the plug or turn off looking at the fan to see how many revolutions is makes with no power applied. It should rotate like five times or more indicating freeness. If it hals to a stop immediately after power is removed the motor bearings are tight.
If your handy you take apart and oil the shafts using 3inone motor lube. Clean the motor of dust and dirt drop a few drops on the shafts near the bearings then work it in by hand rotating the blades. Do this a few times reassemble then ler ripp!!!
Feb 15, 2011 | Vornado VH2 Compact Heater
I am writing about a vornado TouchStone Vortex 500 Heater. I plugged in another heat in another room and the lights went out. I reset the circuit breaker but the Vornado will not turn on. Cathy Giuli...
Call 1-800-234-0604 - This is Vornado's consumer service line. This manufacturer is well known for great customer service, and they should be able to tell you if something is wrong with the unit. If so, and if the heater is under warranty, they will fix it or replace it for free. You won't even have to pay shipping to send the unit in.
Oct 22, 2010 | Vornado TouchStone Vortex Heat 500 Heater
Vornado VH2 heater appears to switch on, but fan and heating element no longer come on. Any solutions?
Dec 22, 2009 | Vornado VH2 Compact Heater
Does not turn on
This is a pretty common issue with these heaters. The switch can easily be replaced by opening the unit and swapping out the switch assembly. One switch I have found that works well and is reatively inexpensive (under $4) is the one from Radio Shack (P# 275-0020) which is a 16A 125VAC illuminated round rocker switch. Unlike the OEM one that drops in, the RS one is a panel type which you will have to screw into place. The whole procedure shouldn't take you more than 15min.
Dec 21, 2009 | Vornado VH2 Compact Heater
I need a new on/off switch
I have the same problem with a VH Vornado heater
No need to change switch.
The switch has to sets of contacts, but uses only one. This one is burnt out
Just reconnect the black cable (hot) to the opposite free switch connector.
Then interchange the white (resistance) with the brown cable (ground for switch light)
You may have to turn around the switch because the heater will turn on on the "OFF" position
Check your cables with tester, to avoid any short circuit.
Dec 15, 2009 | Vornado REH1-0001-01 VortexHeat Compact...
Jan 19, 2009 | Vornado VH2 Compact Heater
1.take apart heater
2.remove fan
3.wipe of bearings
5.asemble
6.test
Jan 08, 2009 | Vornado VH2 Compact Heater
Thank you.
Nov 19, 2008 | Vornado TouchStone Vortex Heat 500 Heater
Vornado VH2 Compact Heater Logo
82 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
Lyle Siemens
Lyle Siemens
Roberto Lopez
Level 1 Expert
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
