What are the problem that the t460hw02 v0?On a sanyo dp46848
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
Why is my screen too white?
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 25, 2014 | Sanyo DP46848 LCD TV
No picture there used to be lines at the top
It sounds that there is some loose contacts with any cable connectors, or to any solder terminals at the circuit board. It will be best to contact any service technician, or the authorized service center for Sanyo. Gopakumar Gopalan Google
Feb 24, 2014 | Sanyo DP46848 LCD TV
47in sanyo flat screen gets a black shadow across it got to tap it to make it stop but happens alot . model DP46848
You have a defective LCD panel tab connection. The only permanent fix is to replace the panel. A replacement panel will cost more than a new set. I had the same problem with the exact same set.
Feb 08, 2013 | Sanyo DP46848 LCD TV
DO THE SANYO DP42848 AND THE DP46848 LCD TV 2008 MODEL USE THE SAME CIRCUIT BOARDS
No boards in those models interchange with each other. Totally different.
Jun 16, 2011 | Sanyo DP46848 LCD TV
Sanyo DP46848 has sound but no picture.
Tv turn now,have a flashes of picture a few sec.than dies have sound left only?Yes,than ur tv have a 2 long boards are dead that call LCD inverter boards.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 07, 2010 | Sanyo DP46848 LCD TV
I have a SANYO DP46848, after i turn on the TV after a few minutes the picture turns a blue/grey color. There is still a picture and sound, but poor picture quaility. Need some help?
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
Dec 07, 2009 | Sanyo DP46848 LCD TV
My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Oct 21, 2009 | Sanyo Televison & Video
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
Electro Med Services...
