Question about Jenn-Air 24 in. DW731 Built-in Dishwasher
Model DW730B----Problem ,-- Will not drain waterstanding in bottom of wash area
  • cummins17 Dec 31, 2010
    waiting for answer
  • 11,896 Answers
This can be caused by a couple different things. Either the drain may be slightly clogged, or the timer is off making the machine think it's drain cycle is over with even though it's not. Or the water level sensor is faulty tricking the machine into thinking all the water is gone when it's not. You can get free diagrams and part locations from partselect,com The water level sensor can be cleaned and tested with a multi-tester. The timer can also be tested for continuity. The drain screen and lint trap can both be removed and cleaned out which may help your problem.
Posted on Dec 31, 2010
My washing machine leaks alot of water from the drain trap while it is working or when it has just done a wash.
Thanks for the model number. The leakage is very likely from the drain hoses that are connected to the drain pump. For your model the drain pump is located at the bottom front behind the bottom plate. You will have to remove the screws holding the bottom front plate. Once you get this out you can access the drain pump and hoses. Either one of the two hoses (inlet from drum or outlet to laundry drain hose) could have burst or lost hose clamp. Need to fix this. Also check the laundry tub drains are clear and there is no back water into washing machine.
May 01, 2014 | Washing Machines
Smeg Dishwasher not circulating water
Sound like the thermostat doesn't know what the water temperature is set at.
It could be the wash pump. Check to see that the float on the bottom of the DW is unstuck by gently picking it up and setting it down { It is shaped like a mushroom and controls the water level in the bottom of the DW }. Did it move freely?
Dec 29, 2013 | Dishwashers
Washer 4000 series 4.5 cu ft
The newer model Maytag washers are manufactured by Whirlpool and have Whirlpool parts. If this is a Maytag Epic model washerlb_icon1.png, "F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothinglb_icon1.png such as sock or under garments can commonly clog in this area as well causing the drain cycle to fail.
Nov 16, 2013 | Maytag Washing Machines
Model 66513119k701
I would remove the bottom rack to get access and remove it ...unless the spoon is actually stuck in the drain
Aug 28, 2013 | Kenmore 24" Built-In Dishwasher with...
My Kenmore dishwasher does not drain out, What could be the problem?
No drainage, or poor drainage issues are usually caused by either a failed drain pump, or the sump area under the sprayer is clogged with debris. The sump is the area at the bottom of the tub where water collects on the initial fill. A wash pump cycles the water throughout the wash cycle, followed by the same water being drained from the unit by means of a drain pump. This area is usually covered by a coarse screen and fine screen to prevent debris from accumulating. But, over time, some debris may still get past the screens and collect in the sump. This usually results in poor cleaning results due to restricted water flow through the spray arms, and poor draining.
I would recommend you remove the lower spray arm and screens and check the sump area for obstructions. If the unit still has standing water inside, use a wet/dry shop vac to drain. Remove the drain line from your sink and pull a vacuum on the end of the dishwasher drain hose. If the water drains freely from the unit, then you probably have a bad drain pump. If the water will not drain, you have a clog somewhere. Check your drain lines and pump for obstructions.
If you have any questions, please post back with a MODEL NUMBER. I hope this helps you.
Aug 15, 2011 | Kenmore Dishwashers
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
Whirlpool dish washer model number du895s will not drain
check the sump area,check valve at the hose on the bottom of the unit,then check the house drain piping for a blockage,also kinks or obstructions in the hoses
Jul 17, 2010 | Whirlpool DU850SWPB
I have sitting water in bottom of outer ring after wash cycle.
The Neptune will typically have a bit of water in the front seal area after the cycle.
Take a towel and wipe the area clean and dry after heavy loads. There is a drain in the bottom. Wiping this area will help keep the drains clearer and help prevent ordors too.
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Dishwashers Logo
146 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
