Question about Iomega Silver Series 320GB 3.5 External - 7200, 8MB, USB 2.0 320 GB Hard Drive
Hard drive not detected by my pc . power lite is up while connect to pc . pc is amd athalon and usb hard drive is iomega 160gb
    President:
  • 1,812 Answers
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb ,one after one .
After UN install all the usbroot hub, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
Hope it will help you
Posted on Dec 31, 2010
Windows 7 driver for160GB eGo USB 2.0 Portable Hard Drive?
According to the Iomega Support web site you do not need additional drivers for using your Iomega eGo drive with Windows 7 unless you have a USB 3.0 device.
See this Iomega document on what you should do if your drive is not detected on Windows 7
Jan 14, 2012 | Iomega 33914 Storage 160gb Ego Silver...
A friend sent me his iomega HDD 160GB external unit, On the back HD160-U also s/n: OVDE3801TH. I can not get my Acer Aspire 5315-2122 to recognize it How can I get them to work . Please help.
Please try to connect it to a different PC. If the problem persists, the external unit might be faulty and should be returned for warranty if possible. If it works on the second PC, you can get drivers from http://www.iomega.com/
Aug 25, 2011 | Iomega (33600) 160 GB USB 2.0 Hard Drive
When turned on, hard drive will not connect (mount) to computer.
1. Your hard external hard drive may not be supported by the mother board.
It may be to large for the PC to detect.
check *********** board manual to see if the hard drive is compatible with the PC.
2. Check the USB connection with another USB drive to see if it is detected > if so then the 1TB drive may not be compatible with *********** board.
Mar 17, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My Iomega eGo 500 GB Extern Hard Drive stopped working, it says that USB is not recognized (I tried in 4 pc's) and LED is ON. What can I do to get it back working?
if that happens after trying it on different computers then it means the magnetic needle inside the drive is broken and will need to be replaced.
Feb 25, 2011 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
160gb usb 2.0 portable hard drive that is froz
Try plugging it into a different USB port may not be enough power from that port
Dec 06, 2009 | Iomega Computers & Internet
I just bought an iOmega eGo 160GB external hard drive and have no idea how to use it once I've installed the program. Help!!
From what I'm finding; this drive is a USB 2.0 drive. First, you'll need to plug the drive into the computer via the supplied USB cable (if it came with one) and any AC power for the drive if it requires it.
Then, your PC should detect it and you then need to run the software for it to be configured properly.
To use the drive, simply (if in windows) double click my computer and the drive will probably come up with a name such as eGo or iOmega Hard Disk or possibly even External Hard Disk. From there, double click that drive and start copy files! :)
Sep 11, 2008 | Computers & Internet
My msi km400 8237 acpi problem
If you had APM or no power management activated, you will need to reinstall windows after turning on ACPI to load the new ACPI HAL and to detect the hardware again. Otherwise windows will be confused about the type of PC it's installed on.
Jun 24, 2008 | Intel Motherboard
Iomega Silver Series 320GB 3.5 External - 7200, 8MB, USB 2.0 320 GB Hard Drive Logo
236 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
