Question about Maytag Neptune MDE5500AY Electric Dryer
Matag dryer lde412 not heating elec - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
My matag dryer #mcg8000aww heats and then after a few minutes stops heating
you high / low temp thermostat is going bad need to replace it. or your vent is clogged and it is over heating. and shutting down to prevent a fire.
Aug 21, 2014 | Dryers
No heat. Elec. power OK. 12 years old
heatman101
Dec 19, 2010 | Whirlpool WGD5200TQ Gas Dryer
My Maytag LDE412 dryer makes a loud rumbling noise when drying clothes. I have changed the idler pulley but this did not fix the problem. Will I need to change the drum rollers or could I just oil them?
You could try oiling them. I recommend Zoomspout oil. It is used in the HVAC community. It is heat resistance and non-flammable, will not dissipate easily. themobilian_419.jpgGet it at Ace hardware.
Dec 12, 2010 | Maytag Dryers
Matag Legacy gas dryer sometimes it will not heat. Doesn't sound like it's trying to burn. So am guessing it's something to do with getting the signal to light the burner.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Maytag Dryers
No heat
Your problem is more than likely one of the following:
* heat source: elec. heat element, gas coils, gas igniter or radiant sensor (depending on elec. or gas model)
* thermostat
* timer
Feb 19, 2010 | Amana ALE866SB Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
My Maytag elec dryer does not heat. It is a
You have to use a multimeter to test the heating element for continuity and if that is good, you have to test the other sensors. A wiring schematic is included with your unit, someplace on or in the unit.
May 09, 2009 | Maytag Dryers
No power to dryer was working fine no warning would not start
Most likely a bad fuse. There is one above the heat element, also may have one on the blower housing. Test with an ohmmeter or bypass. Hope this helps!
Feb 16, 2009 | Maytag PYE2300AY Electric Dryer
Maytag LDE412 dryer.
Here is a link to the internal diagrams of your model.you can choose among the parts just in case.Good luck.Please do post comments and rate my answer.Thank you for contacting fixya.
LDE412 internal diagrams
Jan 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer no hot air
check power supply and make sure you have correct power. It will run with only 110 volts but wont heat. If good check heating element, thermal fuse.
Jan 05, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
104 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
