Question about Canon Pixma MP500 All-In-One InkJet Printer
How to a scan a piece of paper
I need a scan guide please
  • Funnybunny30 Oct 13, 2008
    I don't know how to scan a document on this exact printer. Can anybody help me?
OUr original software came with an OMNI program which seems to work very well. Did you try to reinstall your drivers? Perhaps it is there. Once that is up you can scan to save or to fax. Just do the settings and colour scan or black and white and when you go to save it. We use the "save image" setting.
Posted on Jul 13, 2008
When you send a fax is the paper face up or face down
It depends on which FAX-machine you are using,
since they're not all the same.
Look for a small icon (like a piece of paper, with one corner folded-over) near the feed-tray, for a pictorial guide.
Or, try it both ways, to see which one works.
Aug 24, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Scanjet G4050 - Image is sometimes at an angle in PDF scan, even though paper and original text was straight. How to prevent this?
Hello
This is a flatbed scanner. Since the paper is aligned to the sides of the scanner the problem could be two things:
- The paper guides on the sides of the scanner are not accurate to the scanning path
- The scanning bar is not moving parallel to the sides of the scanner (one side is slightly ahead of the other side).
I had a similar flatbed scanner and the paper guide was off about 1/16" - so all scans were either tilted or I had to manually move the paper on the glass to correct.
HP do have directions on how to maintain your scanner - http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=125&prodTypeId=15179&prodSeriesId=3236371
- but it does not include any info on how to re-calibrate it. So it would appear that this is something you will have to manually correct.
Download and print out something with a grid or ruler measurement on it. This site has some examples - http://www.imaging-resource.com/PRODS/HPPSS/PSRESV.HTM
Align the page normally and scan it with your scanner, print the results. Compare the scanned print to the normal page and adjust the paper accordingly on the scanner.
Once you have the new location for originals on your scanner, take some construction paper or poster board and trim out pieces to tape or glue to the glass of the scanner to form a new paper guide.
While a calibration tool would be better, this method will definitely work.
Dec 03, 2009 | HP Office Equipment & Supplies
It showing error paper is jammed , but there is no paper in there
Hello, you may have a piece of paper (even a small piece) lost in the printer. Please lift the covers and remove any paper trays. Use a flashlight if you can and carefully look for any paper stuck anywhere inside the paper feed paths, where paper goes in our out of the machine. If you need help on how to open up the machine, Canon has info on their web-site or the "easy setup guide" that came with it to show how things open.
If this is not the problem you may need to reset the machine to clear the error. Unplug the machine and leave sit overnight (worst case only if needed).
Oct 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer will not scan pictures.
Introduction To use the scan features, the HP All-in-One and computer must be connected to each other and turned on. The HP All-in-One software must also be installed and running on the computer prior to scanning. To verify that the HP All-in-One software is running on a Windows computer, look for the HP Digital Imaging Monitor in the system tray at the lower right side of the screen, near the time. NOTE: Closing the HP Windows system tray icon can cause the HP All-in-One to lose some of its scan functionality and result in a No Connection error message. If this happens, correct it by restarting the computer or by starting the HP Image Zone software. Follow the instructions below to scan documents from the all-in-one to an application. Make a Scan Step one: Load paper
  1. Open the paper tray door. Figure 1: Opening the paper tray door c00315283.gif
  2. Pull the paper tray extender toward you, as far as it will go. Flip the paper catch at the end of the paper tray extender to open the extender the rest of the way. WARNING: Legal paper might get caught on the paper tray extender if it is fully extended when you print onto legal paper. To avoid a paper jam when using legal-size paper, do not open the paper tray extender.
  3. Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide to its outermost position. Figure 2: Sliding the paper-width guide to the outermost position c00315284.gif
  4. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  5. Insert the stack of paper into the paper tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops. NOTE: If using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the paper tray. Figure 3: Inserting paper into the all-in-one c00315285.gif Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Sliding the paper-width guide to the edge of the paper c00315286.gif Do not overload the paper tray; make sure the stack of paper fits within the paper tray and is no higher than the top of the paper-width guide.
Step two: Load the original NOTE: Many of the special copying features will not work correctly if the glass and lid backing are not clean.
  1. Lift the lid and place the original face down on the left front corner of the glass, with the sides of the original touching the left and bottom edges. NOTE: For more help on loading an original, refer to the guide engraved under the glass.
  2. Close the lid.
Step three: Scan to an application NOTE: To use this feature, you must have installed the full software package and the HP Digital Imaging Monitor must be running.
  1. Press Scan on the control panel. A preview image of the scan displays in the HP Document Viewer window on the computer, where you can edit it.
  2. Click Done or Finish in the software. The HP All-in-One sends the scan to the HP Image Zone software, which automatically opens and displays the image.
NOTE: To stop scanning, press the Cancel button on the control panel, or in the HP Image Zone software, click Cancel . Have a good day,
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Paper jam on upper rollers.
check the out paper path guide, a small piece of plastic or toner material can collect and cause jams. Run your finger along it to check and see if its rough if so carefully file down the paper guide
Nov 01, 2008 | Samsung CLP-600N Laser Printer
How do I fix blurred printing. Is it the drum?
this could be as simple as a static in your paper issue or it could be a problem toner or could be a problem with the fuser, to eliminate these 1 by 1 start with the paper by taking a sponge and wiping down a piece of paper( dont make the paper sopping wet you just need to put some moisture in it) then run a job with this piece of paper and see if the quality came back, if it's good then you have a static issue with the paper and you need to use differant paper. If you need to test further, run another job like you normally would but try and stop the machine by opening it up before the paper reaches the fuser but after it has print on it from the toner cartridge, carefully remove the paper as the toner will not be melted into the paper yet and check to see if the quality issue exists on this print, if it does then it will be a toner issue and if not, your probably looking at a fuser issue which will need to be replaced... if this helps, please leave the fixya feedback...
May 13, 2008 | Samsung CLP-550N Laser Printer
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Canon Pixma MP500 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
