Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
When i plug to the cpu monitor cut off the power and green light is blinc
    Sergeant:
  • 223 Answers
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Posted on Dec 31, 2010
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
The cpu is running,the motherboard is with green light inside,but the monitor blanck
what king of monitor you have., crt or LCD, does the monitor led indicator has a green light, is there any beep when starting the cpu? how many beeps you have heard when the cpu was starting?.
if there is no led indicator light in you monitor the posibilities of that is the monitor was the problem.
solution: try to check your plug in monitor if it is properly inserted in the power plug or in the vga plug correctly.
if when you power the cpu and your monitor led indicator, turn green and back in the standby mode. listen to the beep sound of cpu if theres any.
solution: try eject the mem card. in the slot and clean the contact with the eraser. and put it back into the slot again after you clean it.
Mar 28, 2011 | Computers & Internet
How i could get sound from monitor speakers Do I need to connect cord between cpu and monitor
Hi
Yes you will nned to connect the cord between th monitor and CPU, on the cPU you will need to plug the cord into the light green connector
Regards
Shauqat
Sep 26, 2010 | Nokia 500 XA Monitor
Power light blinks red, green and off. No picture
Is there another monitor input on the back of you computer? Sometimes this happens when your graphics card is not compatible so it is best to try another one. If you have another one plug it in there first. If you don't try the monitor on a friends computer. If it still does the same thing, it may be a manufacturer defect and may need repair.
Nov 06, 2009 | Planar PL1911M-BK (Black) 19" LCD Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computers & Internet
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
101 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
