Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Hi sir/ Mm
  • my power book g4 is not coming on and the LCD screen is not coming on but the hard drive will be spinning
  • Anonymous May 11, 2010
    If you have sound turned on, one of the first things that happen is the computer will make a boot chime. Does this happen? If so, this problem is likely just the display (and we can troubleshoot further).
    Let me know if that happens.
  • Glenn Upton-Fletcher May 11, 2010
    Do you hear the start up chime as normal? What were you last doing before this problem happened?
    Novelist:
  • 137 Answers
Look closely at the screen. You might have to change the lighting or shine a powerful light from the back of the screen, through the Apple logo. If you see a dim image, your problem is either with a bad "inverter" board, a bad "CCFL" light (the bulb that lights the screen), or with the logicboard itself. check back for more info if this is happening.
Posted on Oct 03, 2008
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My g4 power book screen is very dark
This is door to a poor backlight meaning the backlight needs to be changed out. Going to cost like $125 for the part if you do not know how to do it then a tech will need to get involved so tack on your labor. I hope this helps as it did dozens of people with the same issue. please do leave ratings and feedback for your free answer today.
Apr 27, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Possible hard drive failure
Does the splash screen come up? Most of the time if it is your hard drive the ACER splash screen will come up and then a Hard disk 0 error after that. If nothing appears on the screen then you have a bigger issue.
Is there any noise at all (Fan, hard drive spinning)? If so try hooking it to a external monitor to see if there is any movement. You might have a problem with your LCD.
Apr 20, 2010 | Acer Aspire One PC Notebook
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My portable hard drive is not recognized by my Mac G4 power book
You have to run mac tools that is on that hard drive prior to plugging it in.
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
Powerbook g4 15 not turning on
Something is wrong with the operating system. If there is a flashing folder with a question mark, then it might be with the hard drive as well. If you just get that warning, then you may only have to reinstall your operating system (OS X). Get your CD/DVDs out and insert the OS X disk. Hold down C when you start the computer so it will start from the disk and not from the hard drive. After the startup program has loaded, you can try to check the hard drive and repair permissions and such to see if that works, or you can just reinstall the OS. Good luck.
Mar 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Stuck on initial screen on power up
sounds like your hard drive died, you should take it into a repair shop unless you know someone that can replace the drive and re-install OS X for you. you computer uses a 2.5" laptop hard drive.
Jan 29, 2009 | Apple Mac mini G4 Desktop
I book g4
Some of the start up files have been corrupted or are missing. Start up from the OSX system disc and them run Disc Utilities from the installer toolbar. Check the hard drive for errors. Repair any errors if they are found. If it's not possible for Disc First Aid to repair the hard drive you will need to replace the drive and re-install OSX.
Dec 30, 2008 | Apple iMac G4 Desktop
80 gb hard drive from apple pro book does not work
Try using Disk Utility to mount the drive. This can be found in the Utilities folder within the main applications folder. Launch Disk utility and see if the drive comes up in the list of drives down the left hand side. I presume that the hard drive in the enclosure is spinning. You can normally hear it, and feel a constant light vibration.
May 29, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
127 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
