Question about Dishwashers
Ariston K-L61 dishwasher not heating water intermittent fault. Before I order costly spares and remove unit from built-in cabinet, any idea what problems might be?
5 Suggested Answers
  • 641 Answers
SOURCE: Ariston L63 Dishwaher problem
Unplug the power cable, remove the service panel and follow the next steps : - Remove one of the wires connected to the heating element and check with a multi-meter the element's resistance. In case you can't read any result,you should replace the element. - Check the water level switch- The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub.Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. - Control panel - look for loose wires. If you think that your main control PCB timer have failed, you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck !
Posted on Sep 13, 2007
  • 171 Answers
SOURCE: Dishwasher insulation for heat
Hi marseibold,
I'm Harvey the Master Plumber.
Your questoin is: You're wondering if you can further insulate your dishwasher for heat. You are redoing your kitchen, new appliances, cabinets, etc. and shortsightedly put the spice sliding pull-out cabinet next to the dishwasher. The spices get warm when you use the dishwasher. There is a bit of room between the cabinet and dishwasher. Any recommendations for further insulation?
Yes. I would get another insulation blanket off a d/w I'm disposing. Anyway, you need to get one and install it over the old one to decrease the heat transfer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 122 Answers
SOURCE: dishwasher for 32 inch cabinets
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Posted on Jan 05, 2009
SOURCE: ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Posted on Feb 14, 2009
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Water is cold
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Jun 08, 2010 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
How complicated is it to replace the heating element in the whirlpool gu1500xtls1 Dishwasher? It is not drying. Can the element be replaced from inside the unit or does it does the whole dw have to be...
would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Feb 23, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Ariston dishwasher
Feb 09, 2009 | Ariston Technologies L63 Free-Standing...
Ariston Microgenus 27mffi combi boiler
im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Aug 29, 2008 | Combi Centre DX - Mango
Does not dry all the way
I too have a similar problem. Drying light blinks, doesn't shut off, little if any steam escapes when door is open during drying cycle. Wonder if this is Ariston's Dynamic Drying? My unit is new too.
Aug 20, 2008 | Ariston Technologies LL64WNA Built-in...
My dishwasher trips out on certain cycles
sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Jun 05, 2007 | Ariston Technologies L63SNA Stainless...
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
Owen Barnes
