Question about Sony Playstation 3 (PS3) Console
Unit will not power up, front led goes green there after it goes red and shuts down. I can hear the fan kiking in but then it shuts down.
  • 21 Answers
Im afraid to say its packed up,it happened to mine last year,couldnt even get my game out.you can either get in touch with sony or look up a shop that does ps3 reapairs
Posted on Dec 31, 2010
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Sony kdf-37h1000. push power button and the green lite comes on steady and i can hear a fan. never gets to a picture or sound. it then sounds like it shuts power off but lite goes from flashing green to...
Hi catfishbob,
You're lamp came to its peak burning life and now its dead that's why you can't power up the unit and the led light keeps flashing. Once the lamp replace with new one your unit will back to normal again. Click this link for the replacement http://shop.ebay.com/i.html?_nkw=KDF-37H1000&_sacat=0&_odkw=sylvania+ld370sc8s&_osacat=0&_trksid=p3286.c0.m270.l1313.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Sony KDF-37H1000 37" HDTV
We have a Samsung HL67A510 and when I turn it on, I can hear a click and the green LED light blinks and the "on" music plays and I can hear the fan blowing in the back. But after a couple of...
Hi Isnovero,
The main reasons of your problem is the bulb which is already came to its end. The unit will automatically shuts off when it sense a bulb failure. But before you replace the bulb I would advice you to work first on its power supply. Look for open fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms like what it showing now. If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Hope I helped you.
Have a nice day! Thanks for using Fixya.
Feb 17, 2011 | Televison & Video
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Unresponsive, lamp dies upon start
if you don't hear a high-pitched whir, the colorwheel is shot and needs replacing. if you do, one of the fans might not be working and the heat shuts it off so as not to cause damage.
Oct 15, 2009 | InFocus ScreenPlay 4805 Multimedia...
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Automatic power shut off
Hold right left and power all at the same time and it will reset...
Jul 23, 2008 | Mitsubishi XL1XU Multimedia Projector
Panasonic PT L501U Projector
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
Apr 17, 2008 | Office Equipment & Supplies
Relays click. That's about it
try unhooking the wires coming off the power board you should be able to unhook every thing except the switch wire and se plug if the green lights stay on and the red don't come on then you have something loading down your power supply if it still shuts down you need a new power supply
Nov 20, 2007 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Help I have no picture, no sound. red light on front, 3 out of 4 green leds inside.
i would first replace the convergance ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 22, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
