Question about Brother GX-6750 Typewriter
Resttime@earthlink.netI put in the paper and start to type. I go about 10 strokes when my carriage goes to the left edge of the sheet and stays there I have tried to delete the tab and margin commands, but it does not work. I need help
  • Brother Master
  • 3,594 Answers
You probably have 2 problems. The R, margin is set near the left and auto return is on.
Happy New Year
DickyO
Posted on Dec 31, 2010
Deluxe. Why doesn't carriage move all the way to the right?
seems like there is a stop that needs moved , but it's been 55 years since I had a typewriter so you just need to look for it
Aug 29, 2015 | Royal Office Equipment & Supplies
Plotter wont recognize edge of clear films when loaded from a roll or sheet. recognized plain paper fine
I would check the sensor on the carriage that detects paper. It might be dirty enough that printer cannot detect the subtle edge of the clear film. It is the blue light that turns on on the bottom of the carriage when you load paper.
Apr 18, 2015 | HP DesignJet 1050c plus InkJet Printer
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • If it's wrinkled when it ejects, the paper may be damp or too thin.
    • Do not load paper with holes punched in it for insertion in a binder.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
False "paper jam" signal prevents printing: My HP 2210 had been working fine. Suddenly, when I try to print, the paper starts to feed for a few inches and then stops. I get a "clear paper jam" error...
it's probably due to what i would call the print head blocker ( on your left handside of your printer head) that is broken . check it out! it also responsable to control how far goes the sheet before start printing.
Jan 14, 2010 | HP PSC 2210 All-In-One InkJet Printer
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My printer cartridge has gone beserk
Follow the instructions below to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Turn on the printer (still disconnected from the computer) and check the lights / lcd screenmag-glass_10x10.gif.
4) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
5) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
6) Try to feed paper manually (using the paper feed button).
7) Before re-connecting the printer to the computer, uninstall the printer driver and restart the computer.
8) Re-install the printer driver.
Oct 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
Brother GX-6750 Typewriter Logo
41 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
