Question about JVC Televison & Video
Blue background and have too much line on the screen
    Top Expert:
  • JVC Master
  • 74,383 Answers
Hello
You haven't mentioned nothing about the sound status of your TV. Assuming sound is there and its ok, I posts this solution.
If the lines are thin and scattered throughout the entire sceen at abou an inch apart or so, Blue Colour Output of your TV has damaged. This section, is integrated on the picture tube base card itself. It can be located at the neck of the picuture tube, pluged onot it with the help of a socket. You can pull it out from the picture tube neck. Be carefull when pulling it out. Never mak a shake upwards of sideways, as it may break the picture tube neck. Just pull it straight backward.
Just look for any dry or bad solderings at that board. I suggest you to resolder suspected soldering points, as loose solderings may be microscopic, and cannot be detected by our naked eye. Make sure not to make any solder bridges in between the adjecent soldering points.
Check the result. If it helps it is ok. If not, measure the voltages at the RED, BLUE and GREEN cathode of the respective picture tube pin points on the CRT base card you just pulled out. They must be almost equal to each other, provided a small difference of 3% or so, is allowable. In your TVs case, if blue output section is damaged, the voltage at that cathode will be very low with respect to the other two. Find out the reason. Normally, the transistor used there as blue output may be leaky. If so replace it. In some TVs, IC or ICs are used in this section. Whatever it may be, the blue output section in your TV is faulty and must be get repaired. I posts this solution, as I indicated earlier, assuming that the sound output is normal. OK.
If you need furthermore assistance, get me through Fixya.
Happy New Year
Posted on Dec 31, 2010
Blue background with "rainbow" like
Check the info from this link to see it it applies to the rainbow lines from your TV.
Jan 04, 2011 | Sony KP-65WS500 65" Rear Projection...
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Samsung Monitor 2232BW
consult a technician you could not do any thing for this fault
Aug 23, 2008 | Samsung 226BW Monitor
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Televison & Video Logo
26 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
