Question about Canon imageRUNNER 400S Copier
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Posted on Jan 30, 2011
I wanted to print and scanned on canon ir2016i directly from my computer. how can i do that? how can i able the printer identify my IP?
if u are on network then u can simply enter the ip address in system settings tab in additional functions.then load the driver ,it will autorun after detecting machine. the scanner is network scanner and will work only in network.
if u are single pc user then load the drive and connect the machine through usb printer port when the driver asks to connect. hola
May 25, 2011 | Canon iR 2016i Black and White Copier
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
How can i established network connection with ir2800 and desktop
First of all you must have a local network hub.Connect your network hub with your computer and the Ir 2800,your IR have to be equip with a network card.(If only have to connect one computer and your computer is not connected to a LAN network,you can use a cross-over cable connected directly from the computer to the IR machine.Give your computer a ip address by right clicing on the local LAN select properties and select internet protocol ver 4,and select a ip address.If your computer is already connected to a network,dont change the ip address go to command prompt tipe in ipconfig/all.This dos command will show you what the ip address is of your computer.
Example the ip address is 192.168.1.10,Select a ip address for your IR by changing the last class to any number.But you must make sure this ip is not in use,lets say you select 25.In the command prompt tipe :ping 192.168.1.25.If you get a reply,dont use the number.Select a number untill you dont get a reply and a time out response.
Now use this IP address and program it on the IR2800 under additional funcktion system setings,network settings,TCP IP settings.
Switch the machine off for a minute and switch it back on.
Now load the printer drivers of the IR and add the port you selected.
Restart the computer,
And print to your computer.
If you have any trouble along the way,just send me a note
Dec 10, 2009 | Canon (6981A002AA) for imagerunner 2200,...
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Canon IR c3200 - CAn't dNetwork Scanning (Simple - Shared Folder)
Hi,ok you have to load the clolor network scangear exe file.If the scangear is installed,click on discoveron the color network scangear tool.It will detect the machine,select the machine.
Then it will be ready to scan into word or other programs.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Mar 15, 2008 | Canon imageRUNNER 400S Copier
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 400S Copier Logo
937 people viewed this question
old marine
old marine
