Samsung HT-TX500. The problem is that the power light flashes. Can not get started there. When I remove the HDMI cable stops flashing but it is still not possible to get the sound system. Some good answers to what it could be wrong?
Hi all. Where can i order/buy a 13 pin cable (system cable) connecting the dvd player to the subwoofer? Samsung ht tx500 home theatre system.
Look in the manual for replacement part numbers - then google-it to find one.
Otherwise, I did find an ebay listing. search for "samsung subwoofer 13-pin" - 1st listing...
It looks correct, but I certainly can't guarantee it will work.
Dec 29, 2014 | Samsung Audio Players & Recorders
We have the home cinema system ht-tx500 samsung and we can not turn it on does not want to work at all the red light just keeps flashing wher you switch on
There are two capasitors in the power supply that I have changed with success. They are 2,2uF/50V and are close to one of the cooling ribs on the secondery side of the power. There is no sign of bulges on top, but if you use a hair dreyer or heat gun and heat them up the product will work as normal. If you cool them down it will stop working again. Change them both, in some cases I have installed 4,7uF/50V instead. Use 105C capasitors to make them more robust againt the heat from the cooling rib.
Jul 15, 2011 | Samsung Televison & Video
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
Ht-tz215 dvd player not playing dvds or cds
try Resetting the system turn power off then press and hold stop button on front panel, power light will flash, hopefully this will sort it for you
Feb 14, 2010 | Samsung HT-TZ215R Theater System
Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
Dec 13, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Oct 06, 2008 | Samsung SWA-4000
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
371 people viewed this question
 Grubhead
Grubhead
