Question about Nokia 2730 Cell Phone
I keep on reformatting my phone (i press the restore all to reformat) but still there's something inside.. and it says memory full but i almost deleted everything in my phone, but my memory card still have space.can anyone help me how to reformat my phone well? pls.. (nokia2730)
U can scan your phone as it can be a virus and can harm your data connect it to your p.c and scan it i guess it'll shoot your trouble
Posted on Jan 02, 2011
I cant reformat my phone memory in my motorola w388, i try to follow the steps to master clear but it still unable to work. is there something i can use to reformat my phone memory??its getting worst
hi!
All you have to do to reformat the memory card is that you have to
insert the memory card, press the Center Select Key,scroll to and select Phone Status, scroll to and select Device Info, scroll to and select Storage Devices,select Memory Card and press Options, and then select Format.When prompted, press Yes to continue or No to cancel formatting.
Another step for you to be able to reformat your memory card is you just have to
press Main Menu,scroll to and Select Settings,scroll to and Select Storage Device,scroll to and Select Memory Card,scroll to and Select Format Memory Card, and then
highlight Yes and press the Center Select Key.
And this will also be an option for you to format your memory card.Here are the steps:
Insert the microSD card.
Press Menu > Settings > Security.
Enter your lock code.
Select Format External Memory. (A warning will be displayed.).
If you are sure you wish to remove all the files from your microSD card, select Yes (left softkey).
Thanks!
Apr 17, 2011 | Motorola Mobility W388 Cell Phone
How to reformat nokia 3230?
Just follow the steps
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
Feb 18, 2011 | Nokia 3230 Cellular Phone
Restart or reformat nokia e 52 becoz of full phone memory
restore factroy settings just press *#7370# and default security code would be 12345
Nov 05, 2010 | Nokia E52 Smartphone
No message but showing phone memory full and not able to send or receive msg
I think you have to do a factoy reset
Before doing this you should know the lock code.
The above mention key sequence is a normal reset.
Press *#7780# Restore factory settings.
Hope it helps.
If the issue persists use this.
Deep Reset (*#7370#) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten(contacts & messages- all phone memory will be gone).
Take a back up if you want something.
Good Luck.
Jun 05, 2010 | Motorola Mobility MOTOROKR EM30 Cell Phone
My n73 displays message"memory full,please delete some data" but my phone memory is completely empty
USED THIS CODE TO REFORMAT YOUR PHONE *#7370# AFTER YOU ENTER THIS"RESTORE ALL ORIGINAL PHONE SETTINGS?PHONE WILL START"WILL APPEAR ON YOUR SREEN,PRESS YES, & THEN LOCK CODE.IF YOU CHANGE THE DEFAULT SECURITY CODE OF YOUR PHONE,PUT THAT CODE,IF NOT PUT 12345 AS THE DEFAULT CODE.WAIT UNTIL YOUR RESTART.DONE....GUDLOCK
Mar 03, 2010 | Nokia N73 Cellular Phone
How to reformat
In case you are able to start your phone, press *#7370# on the idle screen. It shall ask you weather you want to restore the phone to factory settings? Press Yes and enter the security key (default is 12345 unless you have changed it)Your phone shall restart and the internal memory would be cleared off. When it starts again then type *#7780# and perform the same steps again.
In case you are unable to start the phone due to memory full error, please post a comment and we shall provide you further instructions.
Nov 03, 2009 | Lands Phones
Phone memory full
have your phone reformatted by press*#7370# then "okay"(just make sure that you have back up copy of all your important files before doing this.) also, have your memory card reformatted via PC.
May 12, 2009 | LG Chocolate 3 Cell Phone
Best option...
The best bet would be to format both your phone and memory card, although be sure to have a backup of important data. Reformat the card on your computer with a card reader and not using your phone as the virus may just re-infect it as soon as you are done.
1. Remove memory card from phone
2. Format memory card using computer
3. Format phone by pressing *#7370# on the keypad (you will need your security code)
4. Re-insert your memory card and restore your data.
Hope this is helpful.
Nov 28, 2008 | Nokia N70 Cellular Phone
Reformat N73
easy! press and hold * and 3 and Green while pressing the on button. if that don't work, try *#7370# and security code which should be 12345.
Jul 16, 2008 | Nokia N73 Cellular Phone
Reformat
for formatting d phone memory like 6600,3230,7610,6670etc type *#7370# and then press yes..then see d results
Dec 03, 2007 | Nokia 6600
Nokia 2730 Cell Phone Logo
77 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
