Question about Car Audio & Video
On on Pioneer Auto Cd Changer, I am getting a eror code 60. I have purchased a new magazine.What does this code mean?
  • 17,970 Answers
Code 60 means that there was a snag on one of the loading trays or that the process of moving a tray has timed out. CDR to your hearts content. As for fixing said code, carefully take the unit apart and see if anything got jammed.
Those errors mean that there is an electrical or mechanical system fault. The pioneer website suggests to turn the car ingition off and on again, or press the power ON/OFF button on the display unit and try to play the CD again.
Also, I obtain additional information that quote here:
I read that error 60 means "operation timed out". Which just means that the processor in the player asked the mechanism to perform an action, but the action did not happen. If this occurs the processor seems to get confused and just gives up. If you've got a CD loaded into the play heads, you can't eject the magazine because the player won't return the CD to the magazine.
When these things go wrong, it's seldom due to electronic component failure. Common faults are dud switches, broken wires (especially on parts which have to move), and burned-out motors. And of course mechanical jams.
So first get the player out of the boot, and strip it down. Remove the mount brackets and undo ALL the little black screws you can see, including the ones around the socket. Lie it down with the connection socket at the bottom, and lift away the black cover. Pull out the four rubber/silicone damping mounts, then carefully lift the mechanism off the spring mounts (it helps to set these to the H position for this operation). Now tilt the mechanism to the vertical and unclip the flexible ribbon-cable from either one of its end sockets. To do this, use a fingernail to pull out the tiny tabs which are next to the ribbon, in the mounting socket. Make a drawing or photo to remind you how to put it back together. Remember that the tabs have to be held out when it's time to re-insert the cable. When reassembling, be sure that the cable goes right into the socket and that both end tabs go firmly home. Pushing one tab in often pops the other tab out.
Lie the player mechanism down with the rectangular curcuit-board at top-right.
Next job is to get the CD out of the play head, and eject the magazine. At the top-left is a motor with a worm drive, engaged in a cog. If there's a CD in the player mechanism, turn this worm/cog until the CD is wound back into the magazine and the worm/cog won't turn any further. This is important: the last bit of motion sets a switch to tell the machine the player is ready to load another CD. Failure to set the switch leaves the player in an indeterminate state and it won't restart. If turning the cog one way has no effect, try the other. Anti-clock I think is correct but I'm not disassembling again just to make sure. You'll find that for a while turning the cog has no apparent effect, then the last few turns will move the CD all the way home. So don't give up too soon.
Now the CD is back in the magazine, time to eject the magazine itself and rescue your CDs. There's another worm/cog visible in the bottom/middle of the mechanism. Wind this until the magazine ejects. Again if one way doesn't work, go the other. Once the mag has ejected, wind the mechanism in reverse, until the moving metal part clears the white plastic lever which is visible on the middle-right of the mechanism. This will allow the mag to snap back in when you reload it. This is important too, because otherwise when you insert the magazine it will not trigger the 'magazine inserted' switch, and guess what... the processor will be confused again.
Now to fix the actual fault. In my case, it was the ribbon-wire connection to the first motor listed above: i.e. the motor which winds the CDs into and out of the play head. The fault was in the 2-core ribbon-cable which connects the motor to the rectangular citcuit board. This 2-core ribbon is soldered to a multi-core ribbon, just behind the motor itself. The 2-core ribbon disappears into the mechanism underneath the motor, so it can't be inspected. But the fault was confirmed by checking the resistance between those solder connections, and the motor terminals. High resistance: means busted wire. The fix was to solder a short piece of wire from each of the solder connections to the matching motor terminal.
If that's not the fault in your machine, the following are worth trying:
Unmount the rectangular circuit board (three large screws and one extremely tiny screw). Squirt a TINY amount of WD40 into the sliding potentiometer. This device tells the machine which CD the play head is positioned at. If dirt gets in, it will cease to function properly. Make sure the potentiometer pin re-engages in the small vertical slot in the mechanism, when reassembling. (You can just about get a squirt of WD40 in without removing the circuit board, if you're careful.)
Use a multimeter to check that each of the small switches works, both on and off. If not, unsolder from the circuit board and replace or repair. Or just give up... because these switches really are very, very small and hard to repair.
Unsolder one wire from each motor (to protect the circuit board), and connect an alkaline 9V PP3 battery across the motor terminals. If the worm isn't seized but the motor fails to move, then it's dud. Try both directions. Even tiny, sealed motors can be dismantled with care. Though a squirt of WD40 into any hole in the terminal end of the motor case can sometimes be enough to clean the brushes and get it going again.
Remove all the ribbon cables from their terminals, wet a tissue with WD40 and wipe it along the ends of the cable to clean it. Reassemble. (Really, now you're in last-ditch territory.)
Before reassembling, clean away any WD-40 which might get onto the CDs or the magazine, being very careful not to smear any on the play-head sensor.
After reassembling, remember to set the suspension springs to the V position before re-mounting in the boot.
END QUOTE.
If this dont work, you must contact Pioneer for more info.
Hope this helps.
Posted on Dec 31, 2010
I need a 6 disc magazine for my Pioneer PD M530 Multi-disc player. Can anyone tell the model number of the magazine so I can locate one for sale
I may have one for sale. Please let me know by visiting my website, audioserviceclinic.com, and contact me there.Thank you.
Dec 24, 2014 | Pioneer Car Audio & Video
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
The standard cartridge for the Pioneer PD-M501 is the Pioneer JD-M300 6-disc magazine, and you can find them at Amazon.com for $25 new. The JD-M300 fits a lot of different brands of CD players, not just this particular brand and model. And here's a link to a copy of the owner's manual: http://www.scribd.com/doc/22613342/Pioneer-PD-M601-M551-M501
Mar 26, 2010 | Pioneer PD-M603 6-Disc CD Changer
Pioneer cdx p1280 cd changer,the cd magazine will not eject.the power is all ok,tried the rest button bt still no go.
cd changer reqs a verygood 12v source,check for a good earth&check how many volts are going to changer with a good quality voltmeter,check at changer,not head unit
Jul 03, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Pioneer cdx 12 disc changer
According to manual code simply means electrical or mechanical fault - not extremely helpful.
Try to disconnect and reconnect power and it perhaps will reset the problem.
Feb 03, 2008 | Pioneer CDX-FM1289 12-Disc CD Changer
Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Jan 04, 2008 | Pioneer CDX-P1280 12-Disc CD Changer
Replacement disc magazine
manufacture of make of cd changer but it would be cheaper to buy new cd changer i would think but worth you checking
Jan 04, 2008 | Audiovox SP11CDP 10-Disc CD Changer
Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Nov 07, 2007 | Pioneer CDX-FM1279 12-Disc CD Changer
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
