Question about Kidde Nighthawk Combo Gas/co Detector
Shows error, when test/rest button is pushed numbers in 230 range 250 range
    Novelist:
  • 134 Answers
If the display shows "Err", push and hold the Peak Level button. Does the display change to "E09"? If so, then you have just been "had" by the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of Kidde to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy. If it is still under warranty (5 or 7 years depending on date of manufacture) they should replace it. In any event, buy another one; if they replace your first one you will have twice the protection. Not a bad thing. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
Posted on Jan 31, 2011
Pulled tear drop locking mechanism down but keeps springing back NFW7200TW
it looks like you have a bad door switch and is the easiest and cheapest thing to fix on the washer part number 8182634 and it's around 65 dollars.open the door unplug the washer,remove the spring and pull off the rubber boot enough to get at the door switch,remove the screws pull out the switch and unplug it,put it back together,put some soap on the spring so it will go back on easier.hope this helps,also in the washer there's a tech sheet with all the codes and tells you how to run in diagnostics
Apr 07, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Dec 04, 2012 | Washing Machines
Have a lg oven lre30453st that the oven doent work the displa shows F7 clear the clock and unpluged it for 5min and still doesnt work.push the bake button it showed 375 thena second later went to...
Be sure you have 230 volts across the red and black wires at the terminal block the power cord attaches to. I suspect you have only one line to the range.
It is simpler to check a portion of the range first. Go to the relay board for the bake and broil elements. Check for incoming voltage between the red and black wires. You should have 230 volts all the time.
Set the oven control to bake at 350 degrees and check between the yellow and black wires that go to the bake element. You should have 230 volts. If you have 0 volts, check between the yellow wire that goes to the bake element and the black wire that goes to the terminal block of the range. If you have 230 volts here, the DLB relay on the relay board is bad. This will prevent bake and broil from working.
We can go through the relay board for the cooktop. I think it is best to eliminate one problem at a time.
Oct 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
I recently bought an old Craftsman Colormatic Arc Welder but it did not have a manual. Do you know how I can get one? The model number of mine is 113.201 250. The manufacturer number is 1270. It has a...
I'm looking for the manual, as well. Sears Parts Direct has it available for $7.49, but I was hoping to find one online so I wouldn't have to wait for it.
Jun 08, 2011 | Craftsman Garden
Displays "F7" and a continuous
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
May 24, 2011 | Kitchen Ranges
Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
May 29, 2009 | Whirlpool GY396 Electric Kitchen Range
Manual programming my scanner
push the manual button and then enter the frequency number for the channel showing then push the E button.
Aug 03, 2008 | Uniden BC60XLT Handheld Scanner
Thermador 30" Dual-Fuel Range 0FF error
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Xd ! picture error
I'm having the same problem with mine. I'm trying some data recovery programs right now. PhotoSalvage works great for Macs.
Sep 04, 2007 | Olympus FE-230 Digital Camera
GE Spectra XL44
Sister, there is no pilot light on this model. Sounds like you have a bad ignitor, however the F7 code shows as a bad touch pad membrane. d7 must represent how many times this fault occured, although Im not finding anything that shows a d7 code. Try resetting the board by killing power to the range for about a minute. After turning the power back on press the COOKING TIME, DELAY START AND NUMBER 8 PADS ALL TOGETHER. The words test should be displayed. Now you are going to energize the bake circuit; press the bake and start, you should hear a click, this is the bake relay on the board. By holding the start button in you are energizing the ignitor (glow bar) in the oven. If you do not hear the click, suspect the control board. If you do hear the click and the ignitor is not glowing, you have a bad ignitor. Have someone with you to verify the ignitor is glowing when you are holding the start button in. To exit the test, just push CLEAR/OFF key pad. Catriver...post back
Oct 23, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Kidde Nighthawk Combo Gas/co Detector Logo
125 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
