Question about Kenwood Food Processors
We have a FP 730 as a Xmas present. Just tried to use it to chop onions. Assembled in right way and the lugs do lock. Still no power. Tried new fuse but that was not the problem. The liquidiser works fine so it is something to do with the locking mechanism - but it is connecting. Any ideas please? Min@minamonfilm.co.uk
How many pounds of onions should I buy to slice/chop for hamburgers/hotdogs for 100-150 people?
How many slice chops in a lb of Vidalia, Georgia onions. Then use some arithmetic
Jun 01, 2015 | Food Processors
Hi my mom was using her new processor she got today and she put onions in when she noticed it pureed them and left chunks?
When you are trying to chop things in the magic bullet make sure that you use short pulsing movements, don't just hold it down. This will make things go mushy instead.
This is the advice they give on their website:
http://www.buythebullet.com/
You may be over processing your food by letting your Magic Bullet slip into Lock On Mode (see video demonstration of Lock On Mode) when you should be using the Pulse Technique (see video demonstration of the Pulsing Technique). Please read the Pulse Technique instructions on page 15 of the user manual or follow the steps shown in these video demonstrations and you'll be making perfect chopped onion, salsa and all your favorite textured foods in no time.
Dec 26, 2009 | As Seen On TV Magic Bullet Food Processor
Need owners manual for kitchenaid food processor model # KFP740CR
http://www.kitchenaid.com/flash.cmd?/#/page/home
this site should help you out.
one thing, you can chop onions without crying.
Nov 08, 2009 | KitchenAid KFP740 Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Unit assembled, lights are on (pulse, on) nothing happens
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 19, 2009 | KitchenAid KFP740 Food Processor
Blade
Try adjusting the speed up or add the onions a little at a time. Another sugestion would be to use the blade holder and run the onions thru that way ( Shredding them) prior to doing the rest of the reciept with the quad blade.
Nov 21, 2007 | Bravetti Platinum Pro Quad-Blade Food...
Food processor
If the blade is actually fused, I would seek professional help to avoid slicing your fingers off. You can test to see if it is fused by removing the lid of work bowl, twisitng work bowl to the left, and removing the work bowl - if work bowl will not come off (difficult even under normal circumstances), then find out from Cuisinart if you are still under warranty.
Jul 14, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Food processor stopped working
hi there is no reset switch follow these instructions and it suppose to work http://www.useandcaremanuals.com/pdf/FP1300-1400Series791.pdf when you used it did you smell a burned stench? is the unit smells still from it? then probebly the coiles are burend - sorry cant help.... http://www.blackanddeckerappliances.com/customercare/home.jsp good luck
Mar 21, 2006 | Black & Decker FP1300 Quick N Easy Food...
Food Processors Logo
70 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Mitch Vass
Mitch Vass
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
