Question about Zanussi Dryers
My Zanussi dryer TD 901 EC was on along with the washing machine. The fuse box stopped the electrical current on both. When I reconnected the electrical circuit the washing machine went back on but my drier would not go back on. I am wondering if there is something I can do to reconnect the drier to the electrical source as it is still plugged in but not going on. Is there a switch or small part in the cord & plug to be readjusted? As the machine is about 15 years old I am wondering if repairing it through a repair service is worth it. Thanking you in advance. Patricia
    New Friend:
  • 17 Answers
Hi Patricia. Of course it is hae=rd to be sure from a distance, but the electricity supply (fuse box) turned off either because of an over current spike...or a short circuit. I would think it is possibly a short in the Zanussi which may have shut the fuse off and possibly at the same time burned out a live wire inside the machine. My advice...disconnect from power and call a repairman. Hope this helps.
Posted on Apr 22, 2017
SOURCE: Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Posted on Oct 19, 2008
  • 16 Answers
SOURCE: Hotpoint NVL333EYOWW electric dryer
If it doesnt run at all its nothing to do w the thermal aspects at all. The motor would run regardless just no heat. Check all paths electrically to the motor and be sure to check the motor itself.
Posted on Jan 17, 2009
  • 83 Answers
SOURCE: Dryer trips the fuse box
I had this problem with our hoover tumble dryer, it might sound stupid but i changed the plug and it worked ever since, ours blew 5 fuses and tripped out the main fuse every time
hope this helps martin
Posted on Jan 24, 2009
SOURCE: GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Posted on Mar 09, 2009
SOURCE: td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Posted on Jul 28, 2009
Why is my Zanussi dryer stopping after 4 minutes it is heating and tumbling
As you are aware, every year manufacturers of products in this country try to make their products safer, and in the case of clothes dryers, they try to make them less susceptible to fires from accumulated lint.
To that end, it is probable that your clothes dryer has accumulated lint internally, and either some fuse (or fuses) or one of the "shut-off-thermostats" is kicking in every time you start it.
Someone will need to take the whole machine apart and clean out the lint, and check the fuses and thermostats with an electrical tester.
The lint that accumulates is not caught by the lint screen, it is throughout the inside of the machine in the tubing.
God bless your efforts.
( P.S. I have taken several machines apart and found a whole shoe-box full of accumulated lint inside.)
Jun 30, 2016 | Zanussi Dryers
Where is the heater element in Zanussi td 421
They are under the drum in a metal box that is connected to a heater hose and wires. Make sure you unplug it before you work on it. Note the location of the wires that connect to it and also there is a thermal fuse and thermostat that are hooked to the box. Check those too.
Aug 10, 2012 | Zanussi TD4212W Electric Dryer
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
No hot air in zanussi dryer td 160 t
I'm not an appliance engineer nor am I familiar with this make and model but depending on your technical skills you may be able to identify the problem by means of testing internal parts with a multi-meter.
If you feel that the machine will otherwise be binned you have little to lose.
First you must take into consideration safety of yourself and others who may use the machine.
You'l also need a variety of basic tools and a mutli meter.
!ENSURE THAT THE APPLIANCE IS DISCONNECTED FROM THE ELECTRICITY SUPPLY!
You can remove the outer casing and test for continuity in; heater elements, motors, fuses, switches and any wiring from terminal to terminal.
Look for any obvious signs of wear and tear or any possible causes; burnt out components on circuitry, trapped or worn wiring, broken parts etc.
Ensure that when putting it back together anything you may have disconnected is reconnected!
Disconnecting any earth terminals would fail the machines vital safety function. This is of great importance due to the machine using both water and electricity!
Nov 20, 2011 | Zanussi Dryers
Ai need a new motor for zanussi dryer model no td
You'll need to contact Zanussi Service center in case you want to buy new motor, Visit this Link and put your postcode to locate nearby service center.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Zanussi TC7114W Electric Dryer
Td 4212 w Drier is not heating
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Dryers Logo
52 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
