Question about Refrigerators
Water keep running out of the bottom of the freezer door model FFA90 Fridge/Freezer
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
Turn off your freezer before starting, then you need to remove all the freezer drawers and then remove the back panel to expose the defrost element .you then need to clear the build up of ice ,especialy around the centre drain hole,this is best done with a hair drier on low heat (do not melt any plastic parts).you may have to get to the rear of the freezer and clear the drain pipe which goes to the evaporator tray on top of the compressor unit.
once it is running clear you can reassemble the parts and switch back on the power.
Posted on Feb 09, 2009
On my Hotpoint FFA90 fridge freezer occasional leaks occur at the bottom of the freezer where ice accumulates. The fridge section above is fine. Any suggestions?
There is one in the freezer section as well. It's a small white tube. I've had the same thing happen with mine. I just took everything out of the freezer, and used hot water. It's caused by condensation buildup in the drain tube, which then freezes, obviously because it is a freezer after all. Hot water usually does the trick. Just be sure to clean it up, and dry it off really well so it doesn't re-freeze and cause the same issue.
Aug 26, 2016 | Hotpoint FFA90 Bottom Freezer Refrigerator
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint ffa90 bottom freezer only cools down to minus 4
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 28, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Bottom freezer keeps leaking
check your pan under the fridge and see if its dry. Your drain may be clogged. and the water is comming out the door during defrost. paper and food particles clog it.
Apr 26, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Water in fridge
does this fridge have a gulley at the back with a drain hole in the middle? if so, the drain is blocked, push something flexible down the drain till water flows away freely
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge Frezer
Hi I am the lady with the freezer that keeps icing up at the bottom and then dribbles water from the door when you open the door. Did you say to pull the freezer out and do something at the back of unscrew the little panel that is inside the freezer at the bottom?
Jul 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
