Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
My heater wont stay lit .the pilot will light but wont stay lit when u release it to set the temp. ive double checked the gas supply and all is well there . i did get it to light once but after 30- seconds something clicked and it shut down .any guess as to my problem ?
    President:
  • 1,015 Answers
Thanks for choosing FixYa
There are a few different issues that might be the cause of your problem.
The way that the gas control system works on your unit is with a millivolt system. The thermocouple is a located in the pilot flame. When the thermocouple is heated it generates millivoltage to magnetize the gas valve so it will stay open. This acts as a safety system to shut off the heater burner gas in case of pilot outage.
The thermocouple could be defective and need replacement. The part is fairly common to obtain from most home improvement stores as long as your heater uses a unviersal style thermocouple. Some have wired connections instead of a threaded one and others can have a inline safety switch connection so make sure that the one that you purchase is the identical style.
But before you go changing it there are a couple of things to test before doing so...
1. Is the thermocouple is getting proper flame impingement? Make sure that the pilot flame is making good contact with the thermocouple for proper heat transfer. There can be debris in the pilot flame causing it to be restricted so give it a light tap with something hard while it is on. Also make sure the thermocouple has not slipped down out of position.
2. How are the connections to the gas control valve? Check the wiring to the control valve and make sure the screws are tight. Loose connections can cause this problem. If the thermocouple threads into the control then make sure it is not loose. Do not overtighten it. Just make sure it is not loose.
2. Check to make sure the room is not too small for your unit. This unit has a built-in oxygen depletion sensor. It will detect a problem with open oxygen in the room for the burner flame by detecting a smothering condition. Some of these switches are self-resetting and some are manual(push button on the sensor). There could be a problem with the switch(loose wiring,defective switch) or a smothering/restricted burner flame tripping the switch.
If all of these things are testing good then I would lean toward the problem being with the thermocouple. You can test the thermocouple with a fluke meter. Just heat the end with a flame and test the threaded end of the thermocouple(removed from control) with the fluke or multimeter probes(center and side contacts). Set the meter to the millivolt setting and you should get at least 150 millivolts. If you get less then more than likely it is dead.
If you replace the thermocouple and you still have the same issue then it is possible that the control mag head is defective and the gas control valve will need to be replaced.
And here are a couple of things to consider...
1. How comfortable do you feel about making repairs on this appliance? Not to talk you out of trying to make repairs yourself but a gas appliance can be dangerous. There is a chance of fire or explosion if repairs are done improperly or safety precautions are not taken.
2. Is the appliance still unbder warranty? You might still have a warranty and the repairs could be covered.
Well I hope my information is helpful and thanks for using FixYa
Posted on Dec 31, 2010
  • Jim Lee
    Jim Lee Jan 30, 2014
    THANK YOU. I REALLY APPRECIATE THE INFO. YOU ARE GREAT.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you may have a defective thermocouple, its that little rod bar, that the pilot lite touches....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
  • clive beech Nov 03, 2011
    THANKS Barrett very helpful
  • David Hohenbrink
    David Hohenbrink Jan 07, 2015
    not repaired yet thank you for your help
    New Friend:
I have a vangrard bule flame heater works great on LP but won't work on natl.gas is there something I can do for it to work on natl. gas???
Posted on Dec 10, 2012
Heater pilot light will not stay lit after knob is released
99% of the time it is just dirt and dust in the pilot light. NOT a bad thermocouple! These units generate their own power through the pilot light and it has to burn perfectly. Turn off gas supply, remove the cover and the pilot light assembly, including disconnecting the tiny gas line from the gas valve. Blow compressed air in, around and through it to get dust out. Replace everything, use soap bubbles at gas fittings to leak test and light the pilot. I bet it stays lit.
Feb 08, 2014 | Dyna Glo Heating & Cooling
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 27, 2011 | Water Heaters
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
Need to light the pilot light
I am not familiar with this particular brand. What type of heater is it? Normal pilot lighting is done by setting the gas valve to the "Pilot" position and then pushing on the valve to manually open the pilot. After this, light the pilot and continue holding the valve for 30sec to give the thermocouple a chance to heat up. Release the valve and it should stay lit. Turn the gas valve to "On" and you're done. If it doesn't stay lit after releasing the valve, replace the thermocouple. If it doesn't light at all, call a technician out to check gas pressure, orifice, and pilot assembly.
Oct 03, 2009 | Napoleon Heating & Cooling
WE can get the pilot light lit but it will not stay on
You will need to check the pressure regulator for the gas.
It sounds like the gas pressure is to low to keep the pilot lit.
John
Oct 01, 2009 | Desa International Blower Glow Warm Wall...
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pilot light wont stay lit
If this is a new item then you will need to let the gas run alittle bit longer. If this is a used item then it sounds like you are going to need to replace the flame sensor. You may have to even do it on the new item. But usually for the first start you willl need to hold the pilot down for about 1 minute to really let things heat up in there then when you release all will work
May 21, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
993 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
