Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Securoglide roller garage door stops part way down
  • Anonymous Jan 19, 2009
    door goes part way down when press key fob then stops. I then have to hold button in until door reaches ground
  • Vince Heuser May 11, 2010
    need more info
  • 118 Answers
You have problem with the safety eyes. Make sure both lights are on. If not adjust until both light are on.
Posted on Jan 27, 2009
The garage door stops going down even when the door is released from the chain or in this case the screw.does it need lubrication?
Probably yes, or a roller is damaged. Make sure you buy proper garage door lubricant, not WD40. Lubricate the tracks, rollers and all the hinged joints.
Feb 11, 2018 | Building Materials
Garage door opens partway then stops how do I fix it?
First, lubricate the rollers and make sure that one (or more) of the joints in the tracks have not slipped out of line, creating a barrier for the rollers. Second, make sure that nothing (the lift rope?) is hanging down from the door and triggering the safety switch electric eyes, if your door is equipped with them. Third, check the lifting chain or screw, depending on manufacturer, to make sure it's not jamming or in need of lubrication.
Clear silicone is a good all-purpose lubricant for garage door systems.
Oct 27, 2017 | Building Materials
I have a 6 year old craftsman 1/2 HP model139.53985D garage door opener. Sometimes it open/closes fine - other times it opens or closes 6 inches at a time and stops. Springs are fine, worm gear is fine -...
Generally when the door is closing any problem will cause the door to reverse to the open position and stop. This is designed into it. You say your opener just stops when going up or down. This makes me think there is a bad connection somewhere and you are simply losing power. If this is so you should notice that all the small lights that are normally on go out. If this only occurs when the door is going up you may have a bad RPM sensor board. This is a small printed circuit board just in front of the motor.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door: on calm day panels are weather tight
Garage door work like a wedge. As it goes down the door get closer to the jam. So if you moove the weather stips closer to the door that probebly solve your problem. Do that whith the door complitely close.
Good day Paul
Feb 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door not opening properly.
Check the springs on your garage door. If one is broken, the opener will not have enough power to raise up and it will stop like that.Or the up and down limit settings have gone off or bad.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door comes down and goes back up.
You need a general inspection of all related parts. Make sure none of the track mounting bolts have loosened leaving a misalignment of track segments. CAREFULLY with power off use fingers. turn EACH roller. Something as simple as a bad roller bearing can cause this, even a flat spot on a worn roller. Rollers can be bought at a home supply store. These are 2 most causes.
Aug 15, 2009 | Genie Company Genie 34538S Chain Glide...
My 1/2 hp Chamberlain garage door stops while going down even when I am holding the wall unit. If I stop it and restart it goes a little further and then stops. Both sensors have green lights and they are...
On the back of the motor unit you will find the down force control. You may have to remove a light lens depending on your model. Increase this a 1/4 turn and try.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
112 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
