Question about Microwave Ovens
The oven won't switch off even though the knobs are in the off position.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
First remove power from the unit, if that does not help to reset the unit, then you have a defective button or control card.
Careless troubleshooting of a microwave oven can result in death or worse. Experienced technicians have met their maker as a result of a momentary lapse of judgement while testing an oven with the cover removed. Microwave ovens are without a doubt, the most deadly type of consumer electronic equipment in wide spread use.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Oven is off door closed and turntable is still turning in reverse
Most likely, one of the door switches has become non-functional.
Its usually the upper one. Test it with an ohm meter to make sure it makes contact in both positions.
May 05, 2016 | In Microwave Ovens
How can I access the switch for the hi low off light?
The cabinet has to be removed, BUT removal exposes you to hazardous and potentially fatal voltages even with primary power disconnected.
Oct 22, 2015 | LG LMVM1935 Convection/Microwave Oven
Frigidaire microwave won't start when door is closed. It looks like the door does not latch properly. It worked 20 minutes ago and last night. How do you troubleshoot and/or fix the switches.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Feb 23, 2013 | Frigidaire FMV157GM Microwave Oven
My microwave won't heat
The real clue here is strangely enough the table not turning.
All units have a switch in the side (usually the right side) of the cabinet--when door is opened it allows the unit to work but will not heat or the table (usually both) will not work.
It has to be got at from the inside of the unit--little plastic holder with the switch which looks like a leaf switch.
What I have seen several times (including a unit I own) is that from countless opening and closing the door the holder may break or even melt and the contacts on the switch no longer are in position to work when door is open.
The purpose of such a switch is simple---it prevents the unit from being used if the door is OPEN.
Not a hard or expensive repair
Dec 06, 2012 | GE Profile Spacemaker XL 1800 36"...
My surface light bulb burned out and I replaced it with a new bulb. But now the bulb stays lit and it won't turn off even though I turn it off from the light switch. Please help.
The only fix for it is to either buy another control board $300+ or if you are any good at wiring you can go the the hardware store get a manual toggle switch and install it under the microwave on the right hand side near the control area. But make sure the switch can handle the heat rising from the stove burners. We have about 120 of the microwaves on our properties and 6 of them have this issue. The relay internal switch becomes corroded and binds together from steam and boiling water. GE is JUNK.
Oct 30, 2011 | GE JVM1790 1000 Watts Convection /...
Gas cook top electronic ign klick all the time
One of your ignition switches has slipped out of place or is stuck in the ON position.
There is one switch behind each knob.
Feb 25, 2011 | Microwave Ovens
My left front burner igniter stays on even with the knob in the off position, whats wrong?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Nov 11, 2010 | Tappan Microwave Ovens
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
