Question about Masterbuilt 20070106 Electric Smoker
I PLUGGED IT IT PUT THE TEMPERATURE AND TIME INTO AND INSTEAD OF HEATING IT GIVES EAAF READOUT WHAT DOES IT MEAN?
  • 2,299 Answers
Basically this code is telling you that your smoker is to cold. When you open the smoker door and look at the back you will see a sensor (small piece of metal sticking out). This needs to be warmed up and your smoker should work fine. I just ran hot water over a paper towel and stuck it on the sensor until a temp reading was on the display. Then hit set time and it should work.
Posted on Jan 05, 2011
Lg oven not heating after self cleaning. code f9
F9 stands for oven no heating. It will be displayed if oven temperature readout when oven temperature doesn't exceed 150F/66C in less than 5 minutes from set time. I would say you may have a heating element malfunction..
Oct 23, 2016 | LG Kitchen Ranges
What is f5 error mean
F5 will be displayed if the selected water temperature is not
reached or the heating element has failed. Check the water
temperature sensor, heating element and element relay.
Check all connections. Whirlpool Customer Service can
be reached at 1 866 698 2538.
Regards,
Dennis
Oct 12, 2014 | Whirlpool Washing Machines
What does e3 mean on kenwood dishwasher
It means it is not heating the water enough. The manual says.. Longer heating time but not reaching required temperature. The possible causes: malfunction of temperature sensor or of heating element
Apr 30, 2012 | Kenwood KDW243A Builtin Dishwasher
Light comes on, but it no longer heats up.
I have a similar model of DeLonghi fryer, and I have read that many customers have problems with their fryers not heating, after owning and using them regularly for some time. Mine gives an error message and stops heating, once in a while. The lights remain on, but it displays an error message on the temperature readout. I've found that detaching the magnetic safety cord and thoroughly cleaning both the cord and the connections on the back of the machine makes a big difference. Your mileage may vary.
Mar 04, 2011 | DeLonghi D14522DZ Deep Fryer
I have a masterbuilt 20070106 and it is flashing a code EAAF. What does that mean?
Internal temperature must be above 40 F. Use a hair dryer on the internal thermostat and it will start right up.
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
I am getting the EAAF code. What does it mean?
The manual said to unplug the smoker and wait 10 secs and then plug it back in. I tried that and it did not solve the problem. However, I did leave it plugged in with that error code while I was searching the web for an answer. Over the next 5 min or so, the error code went away and my smoker started heating up as if it had no issues.
The solution may be to just let it sit for a few min and then it will begin on its own. The only variable I can think of is that I am smoking in cold conditions for the first time. It may be the case that since the smoker was outside in single digit temperatures, that may have triggered the error code. Who knows, in any case, I am back to smoking for Thanksgiving. Crisis averted.
Will not heat
You have a faulty wire or bad heating element, I will bet that it is a wire broken or burned apart. Open the unit and check the wiring from the case to the element and check if it is not severed or burned apart.
Dec 24, 2009 | Masterbuilt ESQ30B Smoker
EAAF Error Code
I went to start my smoker Thanksgiving morning in Denver and I got the EAAF error. I checked all electrical connections and they appeared fine; I next removed the digital control box and stuck it inside my jacket to warm it up (was 15 deg outside) and lit a candle inside the smoker. After 20 min I put everything back together and it worked. Just remember to remove the candle inside the smoker. I plan to call Mastercraft on Monday to see if they can tell me what EAAF means.
Dec 13, 2009 | Masterbuilt 20070106 Electric Smoker
Digital readout says eaaf
The unit will not turn on if the internal temp sensor is below 40 degrees. Warm it with a hot rag or hair dryer, or bring the unit inside to warm up and it will turn on. Once the unit turns on for a minute or so, it will work fine outside.
This isn't the ideal solution, but it will work. I don't know why they don't want the smoker to turn on when it is cold out (unless they are worried that the quick change in temp will damage the heating coil).
Nov 26, 2009 | Masterbuilt 20070106 Electric Smoker
My smoker reads eaaf on he digital printout
I'm having the exact same problem this morning. It worked a few days ago when I "seasoned" it. I read something about the controller being cold sensitive so I brought it inside to see if that works.
Nov 26, 2009 | Viking Grilling
Masterbuilt 20070106 Electric Smoker Logo
70 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
