Question about Microwave Ovens
I tried concentrated sulfuric acid on the baked on aluminum foil and it didn't work after several minutes. Any other suggestions?
  • 3 Answers
Nope mine is melted onto the bottom as well!!!!!!
Posted on Apr 13, 2012
    Brigadier General:
  • 8,909 Answers
Whatever happened? H2SO4 seems a bit drastic. What is the foil stuck to? Won't soaking with hot washing up water remove it?
Posted on Dec 31, 2010
Can i use aluminium foil in convection mode in microwave
It is best to not use aluminum foil in a Microwave since microwaves cant go through it, so It will not heat properly. If you are using it only on Convection It is just fine, it is like using a regular over then. Same kind of issue though if you are using convection, that is to bathe the meat evenly in circulated air. If you cover it in aluminum you lose a little effectiveness of the convection on the food your cooking. If it is to stop splatter just make a small tent over it and maybe tooth pick it down. Letting the air flow get under it but not splatter the entire inside.
Aug 24, 2017 | Microwave Ovens
I put pizza wrapped in aluminum foil into the microwave for 3-5 seconds until i saw sparks.. i took it out and it left black marks on the microwave. How do i get it off? Does the microwave still work?
If you shut it down quick enough the microwave will be operational, to remove the black marks mix baking soda in water and until becomes a paste, apply over affected area's let it sit for 5 minutes and wipe off with clean warm water.
Jun 11, 2012 | Tappan Microwave Ovens
Would like to know how to use the Inverter. Is it for baking & defrosting? Have never used one before and do not have a manual.
Hi ifcope2000,
The inverter in your oven is for defrosting. It works on the basis of weight of the food to be defrost. To use the inverter follow the following steps.
First place the food on the microwave dish and then close the door.
Now press Inverter Turbo Defrost.
Enter the weight of the food using the number pads.
Press Start.Defrosting will start. The time will count down. Larger weight foods will cause a signal
midway through defrosting. If 2 beeps sound, turn over, rearrange foods or shield with aluminum
foil.
Atul
Mar 13, 2011 | Panasonic Microwave Ovens
I put a metal pan with food inside my microwave oven. I heard a popping sound and there are now two tiny black marks pitted into the glass on the door. I can feel the two pitted marks from both inside...
Yes it is safe to continue using the Microwave as long as the integrity of the glass is not compromised and the pitted marks do not exceed 1/4 inch. The RFwave generated by the magnetron is a pretty wide RF wave beam.
If your really concerned you can take the unit to any appliance service center and ask that they perform an RF leakage test. There is really no other way to know if your leakage is within acceptable limits. I can tell you from personal experience that the ony microwave I ever saw demonstrated excessive leakage had either been dropped and had hinge or latch damage.
If your really worried about it and can not get to a service center you can do this test:
- Wrap a tall empty glass with a sheet of aluminum foil and place it about 3 inches away from the microwave in front of the area you where noticed the pitting.
- Run the microwave with a GLASS filled with water of equal size for 1 minute.
- Stand back 3 to 4 feet and watch for any signs of a spark on the aluminum foil.
- As soon as the microwave shuts off check the dry foil wrapped glass for any signs of heat.
(No heat.... no problem. Sparks or Heat = repair time.)
Thanks for choosing FixYa.
Kelly
Sep 21, 2010 | Sharp R-1480 Microwave Oven
Display says "Loc On" and the bake part of the stove is not on, which I need it to be on!!! I am in the middle of baking a cake and this display came on somehow! Please reply!
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Aug 09, 2010 | Microwave Ovens
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Lid for 13 x 9 baking dish
Use aluminium foil to cover the baker. But only in convection case, not for micro waves cooking !
Jul 13, 2017 | GE Advantium 120 Convection/Microwave Oven
Microwave shuts off after a few seconds
Nov 22, 2007. I also had the 3 second shut off problem with my G/E 1650 MWO. Read all the above and tried them all. Finally I just took a 8" x 8" piece of Reynolds Wrap Aluminum foil and but it in an zip lock bag and placed it behind the control panel. It's been working for 2 weeks now. Just take out the 2 screws that hold the vent across the front right above the door. Next on the right side is one screw, take it out and then gently lift the control panel (panel with the buttons) about 1/2" and it will fold out and stay there. put the zip lock bag inside. Close it back up. I'd test it before replacing all the screws. You don't need to un-plug anything. Just don't stick your fingers on all the exposed parts...Mine works great now and didn't cost $0.10.
Oct 26, 2006 | GE JVM1653 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
