Question about AcerPower FV PC Desktop
I've Acer Power 4400 with 256 MB RAM, I just bought 512 SDRAM PC133 which is suitable for AP4400. but it is showing only 128MB including the old and without old also. What should I do?
    Guru:
  • 509 Answers
You can't mix ram chip sets in a desktop computer. They all have to be the same size to work.
Posted on Dec 31, 2010
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
Ram 256 MB but show 128 MB pls send solution
If you have an existing 128Mb RAM module and inserted another 128Mb to give you a total of 256Mb and it stills shows 128Mb. Then the second RAM module may not be compatible or the second RAM module is faulty.
Try and use the same make and type RAM module as the original or insert a 512Mb RAM module instead of two 128Mb RAM modules. There is not much price gap between 512 and 256 Mb RAM.
Nov 01, 2010 | Intel D845GLLY Motherboard
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
I went and bought new ram for my computer. it's an IBM desktop. type 6792. a pc133 512MB sdram. my computer will not pick it up. how do i get the computer to pick up the ram? it is the right kind of ram?
I checked at http://www.buffalotech.com/products/memory/select/select-dimm/ and according the the memory configurator there your IBM Netvista 6792 takes this type of memory which can be ordered from them PC-133mhz SDRAM DIMM 168 pin, it indicated that your pc has 3 slots for memory and the maximum size you can put in each slot is 512 MB which would give you the maximum memory of 1536 MB. I have had problems in the past when replacing memory in IBM PC's some modules won't work because IBM uses different memory than other Manufacturers. But give Buffalo a try, their memory is guaranteed.
Apr 05, 2009 | IBM NetVista PC Desktop
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Max ram ?
Max -> 768 MB (3 x 128MB)
see this link:
http://www.memoryxxl.net/index.php/cPath/2293_2294_34196
/category/dfi-cb61.html
RAM Specifications: Standard RAM: ECC and non-ECC, Unbuffered and Registered, Chipset: Intel 440BX Maximum Ram: 768MB Steckplätze / Slots: 3 (3 banks of 1)
Dec 25, 2008 | DFI CB61 Motherboard
Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Aug 10, 2008 | Asrock P4I45GV R5 Motherboard
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
AcerPower FV PC Desktop Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
