Question about PANDIGITAL 8.0" Digital Photo Frame (PAN802)
I have a logik pf-a720c digital picture frame and it won't display any pictures that are on a USB stick
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: USB cable missing
Is there any qnuestion about the 8inch item?
Posted on Dec 18, 2008
  • 5 Answers
SOURCE: Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Posted on Dec 20, 2008
lollirita
  • 64 Answers
SOURCE: I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
Why does my digital picture frame rotate some pictures?
The picture orientation can be set manually.
You can download a manual here:
http://resources.kodak.com/support/pdf/en/manuals/urg00863/M820_M1020_frames_exUG_GLB_en.pdf
Check chapter "Changing your frame orientation".
May 07, 2014 | Kodak Easyshare M820 Digital Photo Frame...
I have successfully used one USB flash drive memory stick to show pictures on the Logik frame but when I plug in a different memory stick it does not automatically start the slide show. If the enter...
Depending on how the flash drive is formatted the picture frame may not be able to understand the information on the flash drive. Check the operators manual of your frame for the correct format your flash drive needs to be in order for the frame to read the files. Most of the time formatting to FAT is the safest option
Feb 28, 2011 | Computers & Internet
I need a manual for my Paragon digital photo frame.
I have a paragon photo frame. Model PF.A1200D. What settings do I push to get the pictures to display from using a USB stick. I lost my manual
Sep 09, 2010 | Mustek PARAGON 1200 SP Flatbed Scanner
How do you add pictures to the photo fram:
Use PhotoFiltre free photo editor program to edit your pictures.
You may download it from the below link.
http://www.4shared.com/file/gqHN4jSz/pf-setup-en.html
1. Photos should be in .jpeg format.
2. It is better to scale your photos with the above editor to 800x600 pix.
3. Prepare your pictures in a PC using PhotoFiltre. Scale all the pictures.
4. Transfer your pictures from PC to a USB Flash Disk (Memory Bar)
5. Plug USB Flash Disk to your Photo Frame.
6. Probably your photo frame will ask to transfer your pictures from flash disk to internal memory. Accept this and by pressing enter/OK/Set (Any button that changes from one product to another.)
I think it helps.
Jun 15, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
I am having a problem with my digital photo frame DP-352 do you have to keep the usb or memory card from your camera in the the frame at all time to see pictures or can you download them
you can move them to another card (i recomend a cheap usb stick) just move from the camera card to a folder in your computer and then copy them to the usb drive/stick and plug it in the picture frame
Aug 14, 2009 | Coby DP-772 Digital Picture Frame
Picture porportions are wrong, photo elongated
Had the same problem with mine. It happens when trying to display portrait, or vertical, pictures. I don't think there's a way to prevent it other than to display only landscape, or horizontal, pictures.
Jan 07, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Usb stick not loading on dogotal picture frame
Put the stick into the pc and rerformat it and then stick it in the frame
Jan 04, 2009 | Cameras
I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Nov 17, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
PANDIGITAL 8.0" Digital Photo Frame (PAN802) Logo
138 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
