Question about Photography
I have a fujifilm 12.0 megapixel camera .it has a fujifilm 2gb memory card and it keeps saying protected card, could you tell me why its doing this
  • 747 Answers
The card is most likely an SD card which has a lock on the side of it to protect pictures from deletion sometimes this switch gets pushed in the wrong direction. I'm including a "generic" picture/diagram of this switch.
Also you will need to format the memory card before it will work properly and be totally compatible with the camera you will need to look in your camera manual for this information. You didn't give me the model of the camera or I would have been able to direct your to the correct page. Once the memory card has been formatted everything should work just fine.
Posted on Dec 31, 2010
My Camera keeps saying write protect and my memory card does not have a locking tab
If the slide switch has broken off then the easiest solution is to get a new memory card.
Apr 16, 2013 | GE A1455 14.1 Megapixel 5x Optical Zoom...
Internal stoage loss. Protax dc 1200 digital camera
It is possible that the camera's internal storage media has a limited capacity ( I was made to understand only 32mb). Perhaps what you need to do is use an add-on SC Card to the memory with a bigger capacity, say 1Gb.
It is also possible that you simply need to re-format the memory card/storage.
In some models/versions, settings such as in SHQ (super high quality) while in 12 megapixels or high image resolution (4036 X 3026) or such a combination would result in an image size that is quite big and therefore would occupy a big portion of the memory.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 06, 2007 | Cameras
Screen says "Memory Card Protected" and will not take pictures.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2012 | Fujifilm FinePix C10 3x Optical Zoom, 10...
My camera says memory card protected how do i get it off
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 16, 2012 | Fujifilm Slim Camera Case for Fujifilm...
My fujifilm jv200 camera keeps saying protected card.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 05, 2012 | Fuji Cameras
Why can't I take more than 3 pictures with internal memory? It then says internal memory is full.
The camera that you have only has 10 MB of internal memory , if you are taking photographs at 12 megapixels only 3 photographs would fit as each photograph would be around 3 MB each. I would suggest to buy an external memory card and take photographs on that. The internal memory is only for demoing and checking if the camera works and not for standard use. Buy a SD/SDHC card , they are very cheap nowadays and have immense capacity to hold lot more photographs.
Mar 04, 2011 | FUJIFILM A230 Digital Camera
Camera is saying protected card got a 2gb inside
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 12, 2011 | FUJIFILM A170 Digital Camera
Can someone tell me what to do when my GE 5x optical zoom 14.1 megapixel A1455 digital camera will not let me take pics or anything. It keeps saying (Write Protect) whenever I try to take pics. Please...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 27, 2010 | GE A1455 Digital Camera
Camera says protected card
Hi there
Take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Digital Concepts Digital Camera
Fujifilm finpix z
I had this same problem and as the **** above suggested I read the manual. The problem is not in the camera it was on the memory card. There is a little (yellow in my case) slide button on the side of the memory card itself that you can slide to "Lock". Mine was inadvertantly in the Lock position, once I slid it out of the lock position, the "Card Protected" error no longer occurred on my Fujifilm FinePix Z.
Jan 17, 2008 | Fuji FinePix A350 Digital Camera
Photography Logo
51 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
