Question about Air Tools & Compressors
My 8 gal. Jomate air compressor came with an impact wrench tool kit, never had a chance to usw them because of not enough pressure, not it doesn't even want to pump my tires more than 25 psi. I tried to return it but no papers, so I'm stuck with not enough pressure for any thing, any ideas, it 2 yrs old and only used for my tires, any ideas?
  • 223 Answers
I would make sure you have the air pressure regulator fully opened but other than that these are not good compressors and would not recommend anyone to purchase these as i have also made the mistake of owning one and coleman does not stand by there product.
if helpful please rate 4 thumbs.
Posted on Dec 31, 2010
I just bought a craftsman pneumatic 1/2-in drive impact wrench. And used it with my craftsman 4-gallon 1hp air compressor tried to loosen the bolts on my car wheel wouldn't loosen them help
Pneumatic tools are rated in cfm (cubic feet per minute). Your 1 HP air compressor is rated at probably not more than 3 cfm while the 1/2 " impact driver needs at least 8 cfm, maybe 12 chm of air.
The compressor must provide more chm than tool rating needs.
It is a problem, by the time you look at five horse power air compressors and larger, a lot of electric power is needed. A circuit of 220 volts, 20, 30, or more amps would be required to run those large expensive compressors.
If you can, return the air tool and get a good electric tool instead.
Leave those high air volume air tools to shops that are so equipped to use, or invest if you must.
Jul 24, 2017 | Craftsman Air Tools & Compressors
Will 3.8cfm @90lb pressure air compressure 10 gallon 125psi work with impact wrench at average air consumption 8cfm
Air tools demand volumes of air; a 10 gallon is good for something like a finish nailer, or staple gun, or even a nail gun.
It will run the impact wrench, just not for very long, like 10 to 12 seconds if you're lucky.
Most compressors tell you what types of tools they are made for.
And impact gun is best matched with a 21 - 26 gallon compressor.
Nov 03, 2015 | Air Tools & Compressors
Crankshaft pulley r/r
Place the crankshaft pulley bolt removal tool over the end of the crankshaft bolt. Tool will hold the pulley in place while you apply torque to the bolt with an impact wrench. Start the air compressor by plugging it in and turn it on. Set the pressure of the compressor on the highest setting. Attach air hose on the air compressor to the air inlet and the locking mechanism using the quick-connect lock on the end of the air compressor hose. Set the impact wrench to turn counterclockwise. Spray the crankshaft bolt with penetrating oil. Make sure you soak the bolt head in oil so that it is easier for the wrench to remove. Secure the socket end of the wrench to the pulley bolt and pull the trigger on the impact wrench. You might need to reapply penetrating oil several times during this process to loosen the bolt up. Eventually, the bolt will come off 215 lbs torque, and simply stated righty tighty, lefty loosy. Hope this will assist you.
Dec 19, 2011 | 1991 Honda Accord
Is there a special procedure for removing the harmonic balancer? i've tried several times using different methods to no avail. is the main bolt reverse threaded? tools used so far are a breaker bar, a...
The retaining bolt comes off in counter clockwise turn, they most likely used lock tight when it was installed and it is installed at probably 1200 lbs torque. the 21 gal compressor most likely doesn't have the power needed to remove that bolt. Once the bolt is removed you need the special tool to remove that balancer, it is a 3 leg pulley puller with a center insert that sits in the same hole that bolt comes out of and the pulley puller applies pressure to that insert while pulling the pulley off.
Mar 19, 2011 | 1994 Isuzu Rodeo
Im going to buy a compressor ! What is the min scfm comp that will run this tool for small jobs on my car?
Hi and welcome to FixYa, I am Kelly.
Air Tool consumptions are based on 15 seconds per minute (25%) of tool use.
Usage rates refer to the total time that air is flowing through the tool. If your applications result in more extensive usage, calculate air tool requirements as
follows.
(25%) 15 seconds = rated scfm x 1
(50%) 30 seconds = rated scfm x 2
(75%) 45 seconds = rated scfm x 3
(100%) 60 seconds = rated scfm x 4
Your impact wrench is rated a 8 CFM Cubic Feet Per Minute Usage
SCFM is Standard Cubic Feet per Minute (pre-compressed air volume)
I would be more concerned that the plumbing from the compressor tank could support the 8 CFM required by the 1/2" Impact. Remember the Air compressor will recover the pressure loss regardless of size. The only problem your going to have for "small jobs" is if you use too small of an air line to supply the impact wrench you are not going to get the full torque that it will produce to the drive head. In other words... a 1/4" supply line or 1/4 fittings anywhere in the system just isn't going to cut it even at 120 PSI. If you have the patience... a 5 gallon tank compressor that has the output volume required should be all that you need. I have been a mechanic over 4 decades and rarely have to use a 1/2 in impact for very long. Examples of 1/2" vs 3/8" useage. Wheel nuts, crankshaft pulley center bolt, some starters, steering, suspension and rear end parts. Other than that a 3/8" Impact works great.
One other thing you can do if you have an Air-Peen portable tank (with added fittings) is to add that in line with your output hose when your using the impact wrench so that you have longer use times.
I know this does not answer your what SCFM compressor is required question but it will resolve your needs. I just can't see telling someone that is a "small jobs" user to buy a larger compressor when really all they need is more volume for a brief period of time. The re-plumbed 1/2 inch output / in-line Air-Peen tank is a much cheaper and reasonable work around and you can disconnect that tank when your not using the impact wrench.
Lastly... if your inpact wrench has a SMALL male air fitting everything above will be a waste of time. You have to get that volume into the tool without restriction so that the rool will work properly for you.
Thanks for choosing FixYa.
Kelly
Mar 09, 2011 | DeVilbiss Excell ET501 12" Impact Wrench
Craftsman air compressor 2 hp 20 gallon, seems to running o.k. builds up to 100lbs shuts off when it hits 80lbs come back on, but when i run a tool , right around 90lbs the tool dies out and runs week.when...
IT depends on the tool. Some tools require higher cfm. (cubic feet per minute) of air. IF your air line is not large enough, then sometimes 90psi is not enough to operate a tool as there is a pressure drop at the tool. Look at the required cfm for each tool. Find a chart for air line size, cfm and pressure. Most impact wrenches should be used on a minimum 3/8" air hose. You could look at your manual and see what the max pressure is on your compressor. You may be able to decrease the differential pressure e.g off and 100 and on at 90, but then the compressor will cycle more frequently, and may exceed the duty rating of the compressor.
Oct 01, 2010 | Craftsman Air Tools & Compressors
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
Craftsman compressor is weak
You probably have a restriction in the regulator. You may be able to disassemble and clean it but you'll have to relieve the tank.
Dec 05, 2009 | Craftsman Air Tools & Compressors
Wrench Problem
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Ingersoll Rand 236 1/2" Air Impact Wrench
Air drill tips
Aug 27, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Air Tools & Compressors Logo
41 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
